Thread: Disable low oil and oil pressure sensors
Results 1 to 10 of 10
  1. #1 Disable low oil and oil pressure sensors
    Apr 2011
    Tally, FL
    Anyone one know which dtc's to disable so light on the dashboard wont come on anymore?
    Ohio
    If you want to disable the low oil light, splice the two wires together that go into the sensor.
  3. #3 Re: Disable low oil and oil pressure sensors
    SWPA
    Why would you want to disable lights that could potentially save your engine? If the are throwing the lights then replace the sensors.
  4. #4 Re: Disable low oil and oil pressure sensors
    Nov 2011
    NY
    This!!!
  5. #5 Re: Disable low oil and oil pressure sensors
    if the light is on your engine is dead already, unless the sensor has gone bad. if so change it.
  6. #6 Re: Disable low oil and oil pressure sensors
    Apr 2011
    Tally, FL
    Quote Originally Posted by 99PGPGT View Post
    yeah i didnt want to do that just in case if i ever wanted to go back to stock and put the sensors back in
    because im not using them
  7. #7 Re: Disable low oil and oil pressure sensors
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    What you guys don't understand is that he's running a Novi setup (DoubleBlown - put something in your sig alreaday!). With the Novi setup he has an oil feed and return line just like a turbo kit would use. The oil level sensor location now becomes the oil drain return for the Novi. As far as oil pressure gauge goes the stock one is pointless....it's a dummy light and will only come on when the oil pressure is below 5psi......and lets face it, if you're at 5psi of oil pressure there is a good chance the motor is already toast.
    DoubleBlown....just disconnect oil pressure one (open circuit means the light is off) as far as low oil level light clip a paperclip and bend it perfectly to put into the plug. Once the circuit is closed the light will go away. Also use electrical tape to really cover up the end of the connector and go on a ahead and zip tie it up out of the way of the elements.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  8. #8 Re: Disable low oil and oil pressure sensors
    Apr 2011
    Tally, FL
    So disconnecting the oil pressure one wont set off the light like the low oil level one?
  9. #9 Re: Disable low oil and oil pressure sensors
    Apr 2011
    Columbus, OH
    Correct....mine is unplugged right now...no light.
  10. #10 Re: Disable low oil and oil pressure sensors
    I've unplugged many. And anything to jump the connection on the oil level, tape and smile.
  1. tire pressure disable and lots of lifter tick
    By alreadytooken in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2011, 02:22 AM
  2. are these tire pressure sensors one in the same / exact same
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:18 AM
