So I may or may not have been planning on doing this tomorrow but basically I have a wideband and no way to log it... I need a way to dial in my upper maf tables to be consistant so I dont have to deal with randomly going lean twards the higher rpms or rich twards the lower rpms because the table isnt scaling with engine rpm. And then I had a crazy idea...
Im well aware that narrowband 02s arent in any way accurate past 14.4 - 15 afr but they are consistent .. I know this because my buddies gtp with a near perfect maf table has narrowband mv readings that vary less then 15mv at wide open and a wideband that absolutely locks in at 11.8 (e85)... Whats stopping me from tuning the lower half of the maf table normally using ltfts and then using using the narrowband readings at wot to smooth out and make my upper maf table linear and consistent and then eyeballing my wideband to scale the whole upper section by %? untill I have the pcm set to 11.5 PE and a wideband reading of 11.5?
Feel free to call me dumb / crazy... Was just considering giving it a try.
