Thread: reading with hptuners
Results 1 to 12 of 12
  1. #1 reading with hptuners
    grand forks,nd
    i want to start using my tuner,but when i plug it in, click read entire, it goes to step #4, which is pcm preparing, and it shows it failed!? has anybody else had this?
    Also, i cant even do anything else on it because my car isnt licensed with hptuners yet.
    2000 silvermist GT... HPtuned, RallyArmor flaps, 6K headlights, 12K fogs, D.I.Y. shiftkit, flipped dogbones, Plastidipped roof, debadged, led interior, custom 3.5" CAI and is far from racekar... for now
  2. #2 Re: reading with hptuners
    You cant view anything with the tuner untill you license the car to it.
  3. #3 Re: reading with hptuners
    grand forks,nd
    thats the thing guy lol. It was bought from a dude with an 05 cobalt and its licensed for that. it does have 8 credits on it as he bought credits before he sold it. im registered on hptuners, but i cant see how to get started at all, i read that you have to first read the pcm to get the vin number and pcm info to to be able to license it
  4. #4 Re: reading with hptuners
    Read this.
    You'll find all the links you are looking for on how to set up the software with your car.
    New Users: Help files and Demos - HP Tuners Bulletin Board
  5. #5 Re: reading with hptuners
    grand forks,nd
    Thank you sir!
  6. #6 Re: reading with hptuners
    Hope this dude gets it workin^^^ topswap parts for his car are laying in my garage along with the gen5 that needs to go on mine!
    Note both of us have a ton of learning to do!
  7. #7 Re: reading with hptuners
    You can read any pcm (HPT supported) with HPT without it being licensed. You can not edit them. If you are having trouble reading a pcm, try to connect to the car and scan it. If you can scan then you should be able to read. If you still can't read, try unchecking the high speed box on the flash/read window that pops up.
  8. #8 Re: reading with hptuners
    grand forks,nd
    Got it figured out a couple days ago. Changed speed limiter, rev limit, deleted torque management, and just tonight I smoothed out my timing a little. Also licensed and deleted torque management and some DTCs on Vet's coupe this is definitely a learning curve!
  9. #9 Re: reading with hptuners
    There is...the more you talk about it..the more you can start putting the pieces together.
  10. #10 Re: reading with hptuners
    Changing the rev limit was pointless, we dont make power on a stock cam past like 5300 rpms.
    And you do want some TQ Mgnt, personally I would never get rid of it all.
    Namely at shifts.
  12. #12 Re: reading with hptuners
    grand forks,nd
    No,no I changed rev limit lower than stock, just because of that same reason. then changed my shift points back To stock. And my tq management still works with the Trac button on. Otherwise I have it set to kick in at less than 70% throttle, or more than 5100 rpm
  1. When should I get HPTuners?
    By pontiacmanj2 in forum PCM Tuning
    Last Post: 07-03-2012, 09:32 AM
  2. looking at hptuners
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 03-14-2010, 10:30 PM
