Thread: Timing table
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Timing table
    Quincy, Mass
    you have to install everything in compatability mode and run it in it too but yes it works with 7
    No more GP 04 Impala SS Indy:
  2. #22 Re: Timing table
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Dredging up this thread. I got an old lap tap with XP free from work. So I'm tuner ready. ssoooo how do I get an 05 timing on my bin. I have DHP.
    Much Thanks
    97 Bonneville SE Not so much a 97 anymore
  3. #23 Re: Timing table
    Open your file, then find where the listing is for the timing tables. Now open an 05 as well and go to the same. Click and hold, then drag it to your file. When you let go, it should copy/import.
  4. #24 Re: Timing table
    Nov 2009
    Central Jersey
    neat I'm using a 05 GP N/A table right?
  5. #25 Re: Timing table
    IDK, what do you want to use?
  6. #26 Re: Timing table
    Nov 2009
    Central Jersey
    I was told an 05 timing table is the most aggressive I was just making sure if is was the N/A or boosted table. I'm assuming N/A
  7. #27 Re: Timing table
    Use NA for NA. Then be prepared to back it down a little. You likely will end up with a bit of KR unless the planets align.
  8. #28 Re: Timing table
    Nov 2009
    Central Jersey
    Sounds good upward and on ward. I can't wait to uncork the stock crap out of this.
  1. Anyone have a Maf Table for LQ4?
    By rynoman03 in forum PCM Tuning
    Last Post: 06-07-2012, 12:02 AM
  2. Replies: 5
    Last Post: 05-18-2011, 04:20 PM
  3. Actual Timing > Spark Table
    By JoshMcMadMac in forum PCM Tuning
    Last Post: 10-09-2009, 06:49 AM
  4. Can't get timing to match table values!??!
    By DanGTP in forum PCM Tuning
    Last Post: 10-25-2008, 11:45 PM
  5. Eddie's table modifier, my table too big?
    By Sabrewings in forum PCM Tuning
    Last Post: 06-06-2008, 09:00 PM
