So your telling me my Aeroforce gauge is telling me false KR? Even when im running rich? With my mods you would think so but why would it show KR under light throttle and before certain shifts? I'll go up a ramp and with light throttle around (35-45mph) under load it'll show KR like it has and ill let off the throttle and gently get back into it to drop the KR and it'll go away. Never even touching boost also if I do it'll show KR. Let alone my ltft's never stay constant running rich +, some days they'll fluctuate and lean into the -. When i crank it in the morning sometimes it'll not start the first time try it again and its fine for the rest of the day. Like its forgot or the start up tables are wrong, etc. But those morning runs I'll cruise and its smoother like it should be, I can hear the intake the ltft will be around 0-.7 to 1.5 or 2.5 which is when it seems best. Though cruising the ltft should not be 0, example: if im using less then 20-25% throttle and I see 0 on the ltft thats not good because correct me if im wrong you wanna hit 0 or around there for running WOT. After its up to operating temperature 195+ the ltft will usually go + around 3.9 to 5 or 6.8 even 7+ thats casual to heavy stop and go this is way to rich, that cat diagnostics test keeps making it dump fuel to test the cat and im just drowning cylinders with fuel, if I have to stop abruptly and go the car will actually stall or it feels like jumping out of gear. After its warmed up I dont hear the intake anymore I use to hear that filter whine,whistle,whoosh,etc all the time under all acceleration, why not now? If I do a 2 gear 30mph WOT it'll pull nice showed no misfires but the car would hold back then break loose and go harder. Its like 10mph roll, WOT pulls hard, then jumps and pulls even harder like it should like the car was before just WOT and it went until you let off the throttle. Make any sense? I think its the dp along with the rear o2 emulator ****ing with the stock tune. Im running a new M90 Gen3 with stock pulley, so boost has not changed at all. Is it my plugs running AL606@ .60, thought you didn't change those until you drop supercharger pulleys, etc or could it be the ZZP Stg2 P&P heads? Does anyone else aftermarket heads?
