Thread: E85 hard start in mornings or after sitting a while
Results 1 to 12 of 12
  1. #1 E85 hard start in mornings or after sitting a while
    Lapeer,MI
    I put 60lb injectors in my 04 gtp and its running on E85. It runs pretty after changing the ifr table but it has trouble starting. I've tried to cycle the key a few times before starting to see if that was it but that didn't work..
    Is there any table in dhp that I can enrich/lean out the start up afr??
    Sent from my DROID RAZR using Tapatalk 2
    Ohio
    Anytime you put larger injectors in a car, its gonna take a little more to start up
  3. #3 Re: E85 hard start in mornings or after sitting a while
    Out West
    Get the offsets right?
    Whine with your Cheese?
    Lapeer,MI
    If you mean offsetting the ifr table for the new injectors then yes I did that. Was just think maybe there was a commanded enrichment value for start up based on temp..
  5. #5 Re: E85 hard start in mornings or after sitting a while
    Out West
    There's another couple tables that can use some help
    Voltage offset comes to mind. It brought my 42# SVO's in line.
    Lapeer,MI
    Well car is finally back together, months later... I'm gonna be messing with this soon.. I've got the wide-band in it now so hopefully that will help me figure this out..
  7. #7 Re: E85 hard start in mornings or after sitting a while
    Quote Originally Posted by 99pgpgt View Post
    Untrue.
    My car starts up instantly all the time.
  8. #8 Re: E85 hard start in mornings or after sitting a while
    Ohio
    with 42s right?
    i was just saying that anyone that i have seen put like 60s or larger in a car seem to take alittle longer to start
  9. #9 Re: E85 hard start in mornings or after sitting a while
    with 42s right?
    I have 70's in there now.
    No "Tau" (see megasquirt manual) control so fuel trims are slightly off until it warms up completely.
    If this is a function of E85, I cannot comment as I have no experience with the fuel. Only E10.
  10. #10 Re: E85 hard start in mornings or after sitting a while
    Ohio
    ahh i gotcha
    Lapeer,MI
    Well the car is alive again... Hopefully will stay together awhile..
    One thing that's odd is the heads up display doesn't work now. Not sure why.. didn't do anything to the car to disrupt that other than the battery being disconnected for a long time...
    Lapeer,MI
    Went out at lunch. heads up display is just the typical spring failure.. just one more thing to fix..
  1. Hard to start GTP
    By jcnavalacademy in forum General Tech Discussion
    Last Post: 09-12-2013, 09:00 AM
  2. 02 Grand Am wont start in mornings
    By Madness in forum Off Topic Discussion
    Last Post: 06-27-2011, 05:11 PM
  3. hard start
    By jspangler22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2011, 12:43 AM
  4. Car hard to start.
    By gtp99jlp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 11:44 AM
  5. Car hard to start sometimes.
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2008, 07:40 PM
