I am looking for a stock 01 grand prix .bin file and a gtp .bin file so that i can cross the two for my up coming top swap tune.
Darn Scott...you are on top of it today.
Bonnevillepro.com has them in teh tuning section under bins and then by year etc.
Use the GTP bin and call it a day.
Yes.
But that way you can use the L67 MAP and log boost levels.
I would suggest you do it the way you had planned orginally. Transfering over the fueling is usually a bit easier than trying to get the transmission to operate correctly... If you have HPT you cant swap files anyway.
L36 bins dont understand boost or S/C's so as per darks suggestion: don't give a **** and run an L36 MAP sensor somehow.
there is no torque management to move over. You keep the 1 bar map sensor on it. L36 bins "understand" boost just fine, you just need to command a richer AFR in boost, and change the point at which the motor switches to power enrichment mode through the PE enable throttle position table. Boost control solenoid is pointless, so you dont need to mess with one of those, and just run the bypass valve in manual mode.
I assume you found the file. I know it's on BPro.....cause I put them all on there. If you still need others or want more, pm me and I'll link you directly to it.
