Thread: Question about tuning
Results 1 to 18 of 18
  1. #1 Question about tuning
    Mar 2012
    Altoona
    I was really thinking about an overkill tune, But I need help..
    I admit, I have no knowledge how to install things like that in my car, How much do you think It would cost to get installed? and could anybody do it for me for fee? Like perhaps a local gpf member?
    I don't want to end up ruining my car.
  2. #2 Re: Question about tuning
    Josh...if you have the stock airbox. here's how you install it on a 97-03 and it's not much different 04-08
    Remove the rubber tube from airbox to throttle body
    Loosen two 8mm screws holding the airbox together.
    Loosen two 7mm screws holding the connectors to the pcm
    Slide old pcm out, and new in
    Snug the two 7mm screws
    Put the airbox back together and snug the two 8mm screws
    Put the rubber tube back in place
  3. #3 Re: Question about tuning
    Mar 2012
    Altoona
    I don't have a stock airbox though lol, I have a HAI
    But is that all I need to do? It seems so simple haha.
    And once I order the Overkill PCM Its basically just plug and play?
  4. #4 Re: Question about tuning
    yep! literally that simple my man... as far as I know there is no CASE learn or anything like that either...
  5. #5 Re: Question about tuning
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    If the PCM has never been used in that car it might require a crank angle sensor relearn (CASE).
    Above can be performed using a scantool.
    Don't forget to tell the tuner what octane fuel you use and all of your mods.
    Try to connect with other members in reasonable proximity.
  6. #6 Re: Question about tuning
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    Not to take this thread but, if getting a overkill PCM on my 07, is it just basically plug N play? take out old and put in new, no reprogramming or anything?
  7. #7 Re: Question about tuning
    May 2008
    Winnipeg, MB
    mine needed the CASE learn, thats a two second job with the HP tuners system, you can start the car and see if you get a SES light and what codes pop up
    2007 Pontiac Grand Prix
  8. #8 Re: Question about tuning
    Jan 2012
    Anaheim, Ca
    Mine might need that too then if you got a 07 too, i think ill just get it tuned at the shop. MAYBE or just leave it alone, im having second thoughts about modding this car now. Thanks for the info
  9. #9 Re: Question about tuning
    Dec 2010
    Canada
    Aeroforce Interceptor can do a CASE re-learn as well.
  10. #10 Re: Question about tuning
    SE Level Member 02SuperSport's Avatar
    Mar 2012
    Orlando
    So is a CASE re-learn a simple matter of just clearing any codes that pop up with a scanner?
    EDIT that... Google is your friend. I do see there is a basic procedure involved.
    Brian
    '04 GT2
  11. #11 Re: Question about tuning
    Case lean should be done anytime the PCM or any of the timing related sensors are changed.
  12. #12 Re: Question about tuning
    GTP Level Member
    Pittsburgh
    Josh why would you get a Canned tune when you have a local guy that can tune your car?????
    Yes i have HPT and have done all the cars in my area
    2003 SSEi,
  13. #13 Re: Question about tuning
    Saratoga NY
    Quote Originally Posted by 2003 SSEi View Post
    DO IT!!
    Any canned tune sucks balls and they are all essentially the same and a waste of money. Having a custom tune done should be a no-brainer.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  14. #14 Re: Question about tuning
    Mar 2012
    Altoona
    I would love to do that, but nobody wants to come to my area and give me a tune.
    How much might the charge be? xD
  15. #15 Re: Question about tuning
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Joshmoshh View Post
    When you need a water pump changed do you expect the mechanic to come to your house with his tools?
    Get it running decent and take it to the tuner. Well worth the effort.
  16. #16 Re: Question about tuning
    They do actually.
    Tuners seem to charge a little extra and they'll show up at your door.
  17. #17 Re: Question about tuning
    Apr 2009
    Fort Worth TX
    I'm assuming he's already tried. Maybe it's to far for them?..fuel is expensive.
    Matt
    Get your butt down to Pennsylvania and help him. You have your passport? LOL
  18. #18 Re: Question about tuning
    Mar 2012
    Altoona
    Quote Originally Posted by Rico View Post
    Matt
    lol, i'd pay a good chunk of cash :P
  1. Tuning question
    By Impalass in forum General Tech Discussion
    Last Post: 04-07-2012, 01:08 AM
  2. Tuning question
    By Impalass in forum Shops and Community Heroes
    Last Post: 04-04-2012, 10:29 PM
  3. Tuning question
    By 05GTPcmpg in forum PCM Tuning
    Last Post: 06-09-2011, 08:57 PM
  4. Tuning question
    By xsvtank in forum General Tech Discussion
    Last Post: 07-29-2010, 08:14 AM
  5. Quick question about tuning
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-21-2008, 09:49 AM
