Thread: Good afr?
Results 1 to 20 of 20
  1. #1 Good afr?
    I just got a wideband and got it hooked up and I'm showing an afr of 10.5-10.8. That means i'm running rich right? I thought a good afr was around 11.2 or so but i really don't know. Mods in sig. Thanks.
  2. #2 Re: Good afr?
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    You are correct, that is if your engine can handle running leaner.
  3. #3 Re: Good afr?
    Canned tunes tend to run rich.
  4. #4 Re: Good afr?
    Cruising I'm around 14.5-15 ish. Would i be able to lean that out for better gas mileage?
  5. #5 Re: Good afr?
    Dec 2010
    Canada
    IIRC you prefer the lowest of AFRs, yes?
    Its an age-old question. Search for "lean burn".
  6. #6 Re: Good afr?
    The lower the better.
  7. #7 Re: Good afr?
    If I had an exhaust leak would that make me read leaner?
  8. #8 Re: Good afr?
    Out West
    yep rich
    Whine with your Cheese?
  9. #9 Re: Good afr?
    What about if i have an exhaust leak? Would it read leaner than it was?
  10. #10 Re: Good afr?
    Out West
    depends where your wb02 is
  11. #11 Re: Good afr?
    In the rear o2 spot on sd's I think I have a leak somewhere though. Good possiblity its the flex.
  12. #12 Re: Good afr?
    Out West
    most likely yes.
  13. #13 Re: Good afr?
    So i could be running even richer? That sucks.
  14. #14 Re: Good afr?
    Out West
    possible.
  15. #15 Re: Good afr?
    To me thats way to far back. I have mine in the goose neck on the sd headers.
  16. #16 Re: Good afr?
    Does it throw it that far off having it further back? Maybe I should weld an o2 bung on the crossover and put my o2 there and put my wb where the o2 goes?
  17. #17 Re: Good afr?
    Out West
    nbo2 from one bank of cylinders, smart.
  18. #18 Re: Good afr?
    Dont some of the headers have the o2 in the crossover?
  19. #19 Re: Good afr?
    Charles City, IA
    Yeah, having the narrow band in the cross over is fine, as long as you are not tuning off it. Wbstore and zzp both do it, and I have modded some speed daddies to have it like that seams to work fine.
    SMGPFC Two Nipple General
  20. #20 Re: Good afr?
    Out West
    Quote Originally Posted by TheOtherNick View Post
    Just doesn't seem super smart to me. -- Unless you have a wideband operating full time at least, even then i think it hampers the car's ability to self correct fueling. Ideal would be to have b1s1 and b2s1 but GM was too cheap for that.
  1. HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    By chamilton89 in forum Audio, Security & Visual Electronics
    Last Post: 08-06-2012, 09:10 PM
  2. Would this look good, really good, okish, bad, or really bad?
    By Jakescoots in forum Visual/Body Modifications
    Last Post: 02-02-2011, 06:21 PM
  3. Good Bye
    By Thunderturd in forum Off Topic Discussion
    Last Post: 10-31-2010, 03:50 PM
  4. Would These Look Good?
    By jetscrazy44 in forum Visual/Body Modifications
    Last Post: 08-09-2010, 04:43 PM
  5. is this any good?
    By Nickell in forum Off Topic Discussion
    Last Post: 10-12-2009, 06:10 AM
