Thread: correct IFR for 80# injectors?
Results 1 to 13 of 13
  1. #1 correct IFR for 80# injectors?
    anyone know the correct flow rate for inputting 80# siemen injectors in the DHP Powrtuner? i saw one on CGP but wanted to see if there's another calculated format i can possibly try out.
  2. #2 Re: correct IFR for 80# injectors?
    Hey Freeman, Isn't there one in the import thingee on DHP?
  3. #3 Re: correct IFR for 80# injectors?
    umm i dunno lol. i dont even remember the website for DHP anymore lol i'll go and google it
  4. #4 Re: correct IFR for 80# injectors?
    No ...
    When your in the IFR table, right click and choose import. Then look around for injector tables or it says what it has sitting there to import.
  5. #5 Re: correct IFR for 80# injectors?
    or...aslk Pat. he should have all the stuff I had. And I think there was an 80lb in there.
  6. #6 Re: correct IFR for 80# injectors?
    ah i remember now, you're right theres a spreadsheet in the dhp folder that should have the various injector sizes. also one other question, if the maf and/or IFR is off would it cause erroneous trans shifting/converter issues? someone on CGP posted under the pcm and tuning about tuning for 60# and said he felt that his trans/converter was acting up.
  7. #7 Re: correct IFR for 80# injectors?
    bill, the dhp folder only goes up to 65# injectors
  8. #8 Re: correct IFR for 80# injectors?
    See...this is why I dislike DHP..lol Ask Pat..he might have it in a bin.
  9. #9 Re: correct IFR for 80# injectors?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by fst View Post
    This is as about mathmatically simple as anything gets here guys..
    33 (size of stock gtp injector)/80 = .4125
    take your stock value (I think its like 213), and multiply it by the size difference.
    .4125 * 213 = 87.86
  10. #10 Re: correct IFR for 80# injectors?
    Feb 2009
    flintnasty MI
    Some maf tricks and such will cause this (if you are running a AFC/modded maf on 42# injectors, you may find issues).
    The problem most people have with big injectors is the fact that they are trying to run a factory maf file on it for some reason... but you really need to be using a matt m maf / afc or something that moves your maf curve back within "stock range" and skew your injector table significantly.
    I have 105# injectors in my car and my IFR values are around 150.... when they should really be around 60 or something, all because of my AFC pulling out 20%.
  11. #11 Re: correct IFR for 80# injectors?
    DH do u have a sample of what Matt M uses? im using an AFC as well aside from a tuner
  12. #12 Re: correct IFR for 80# injectors?
    Feb 2009
    flintnasty MI
    It would probably be easier for you to make your own as anything I have is going to be for a fixed afc and a 99 maf... But the scaling is not very easy to do mathmatically, so I can try to send something over if I get my laptop fired up sometime.
  13. #13 Re: correct IFR for 80# injectors?
    k....thanks
  1. Correct tie rod nut?
    By Lionel in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2011, 10:12 PM
  2. cant seem to run the 'correct' afr
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 11:24 AM
  3. Is this how to correct?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2009, 01:52 PM
  4. Am I correct?
    By Bogers99GTP in forum Off Topic Discussion
    Last Post: 09-08-2008, 08:25 PM
