I figured out my problem. I put my tb screen in and now it seems pretty normal and now my kr is gone now too.
Hold foot out
Shoot self in foot
Never forget lesson, priceless (specially since you didn't chip a piston yet)
So -30* is normal for a 97 while cruising its at like 20* or so. Ill double check on my next run.
Well i checked after i got off work and i still have kr. It must have been the cooler air this morning that made me have none i guess. But at least my ft's are closer now.
wait, when do you see these knock retards? all the time or just at WOT like in the shift points?
The KR PID has never worked for us with torque. I even exchanged a couple of emails with the developer and sent him a couple of debug things, but it never worked.
Check that you've also chosen the correct predefined additional PIDs for GM in the options menu.
See if you can save some logs and post it so we can see what you're looking at.
I see it at WOT til i let out. Only 2* today.
Mine goes up to 9 at wot and while cruising it jumps to 6 so yeah Idk.
Torque has had functioning KR abilities since may/june timeframe. there was a specific update to address the issue.
remove all gauges
delete all PIDs
update torque
reselect PIDs
readd gauges
Yep, that's the process.
well have the latest version, so I tried to do the process described above but tried to reainstall the app isntead, but no KR shows up and no other extended PIDs such as the transmission stuff.
It's ok though I still got the powrtuner, I only use torque to check if the trims are still in range and any SES codes that show up when I'm too lazy to plug the laptop.
You have to have the paid version of torque the free version doesn't work.
Uninstall Torque, then delete the files for torque off your SD card, then re-install Torque. That is how I got mine to work.
Ok it works now. I got the KR dial working now. It's always 0.0 (since my tune is so awesome lol), it used to be -.- before.
I'm gonna try to go wot for a few seconds next time the ECT is close to 100*C, I'm sure I'll get some KR in there still just to test it.
Now my ft is +8.6 at WOT I really need a tune.
