Thread: Scanner Doesn't Connect To ECM
Results 1 to 5 of 5
  1. #1 Scanner Doesn't Connect To ECM
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    98 GP GT 3.8
    I had my ecm disconnnted when I was pulling the engine and trans out so I wouldn't damage it. Well now after hooking it back up and connecting the batt my scanner doesn't see it and car won't start and the gauges say the fuel is full (it was only 1\4) and abs is on, DIC is just flashing.
    Is there a right way of connecting the ecm back up?
  2. #2 Re: Scanner Doesn't Connect To ECM
    Omaha, NE
    What scanner are you attempting to use?
    Why were the engine and trans out?
  3. #3 Re: Scanner Doesn't Connect To ECM
    Double check the grounds at the lowest transmission stud. There should be the neg battery cable and two grounds. Then at the starter there's the battery cable and two hot leads.
  4. #4 Re: Scanner Doesn't Connect To ECM
    Jun 2011
    Watertown, SD
    They were replaced. My odb2 scanner, thanks i'll check that
  5. #5 Re: Scanner Doesn't Connect To ECM
    Florida
    yeah sounds like something isnt connected correct. grounds are a good start. i'd look for pinched wires too?
  1. Wire with nothing to connect too....
    By Pontiacman76 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2010, 11:32 PM
  2. xbox wont connect to wifi
    By JarenSTi in forum Off Topic Discussion
    Last Post: 04-16-2010, 09:39 PM
  3. Facebook Connect?
    By JDCMoney in forum Off Topic Discussion
    Last Post: 10-28-2009, 10:26 AM
  4. **FIXED**Can't get tuner to connect
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2009, 03:51 PM
  5. connect throttle cable to pre 99 N* TB
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-30-2008, 10:52 AM
