Thread: Tuning question
Results 1 to 9 of 9
  1. #1 Tuning question
    Jun 2011
    Kentucky
    Okay all my problems that I was having with boost issues, I have it narrowed down to the tune I recieved from a guy that lives around here. What exactly can cause boost decrease from a tune. Is it in the shift points, torque management, afr. Just curious.
  2. #2 Re: Tuning question
    Charles City, IA
    What is your issue?
    SMGPFC Two Nipple General
  3. #3 Re: Tuning question
    Banned
    CT
    Quote Originally Posted by 05GTPcmpg View Post
    After reading your issue, here in bold letters... I don't see how a tune could cause boost decrease. I would probably check elsewhere... BBV solenoid, vacuum lines, etc...
    Unless you're only seeing a boost decrease when traction control is working.
  4. #4 Re: Tuning question
    Florida
    Air is getting warmer now. It could be that when it was cold you were seeing higher boost but now that it is warm you won't see as high boost numbers. Cold air will expand more then warm. Hope this helps!
  5. #5 Re: Tuning question
    Jun 2011
    Kentucky
    Well my boost guage is reading 5psi at wot and my vacuum is fine, and even the digitial factory guage inside isnt going all the way up. This is also with a 3.5 pulley, I have checked everything the only thing I can thing of is the tune did something to it.
  6. #6 Re: Tuning question
    Charles City, IA
    Unhook vacuum from the bbv and see if you get full boost.
  7. #7 Re: Tuning question
    do you have an actual scan gauge or is it just the boost gauge?
  8. #8 Re: Tuning question
    Moved to correct section...
  9. #9 Re: Tuning question
    Jun 2011
    Kentucky
    I have a boost guage, dying to get the car running right after I have done all these mods what to see what it can do. I will try unhooking the bypass valve and see what happens.
  1. 1998 Regal GS Tuning Question
    By DrGSXR750 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 04:38 PM
  2. Tuning question
    By xsvtank in forum General Tech Discussion
    Last Post: 07-29-2010, 08:14 AM
  3. Powertuner fuel tuning question......
    By Iron Indian in forum PCM Tuning
    Last Post: 08-23-2008, 09:29 PM
  4. Quick question about tuning
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-21-2008, 09:49 AM
