Thread: Starting Hptuners
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 99
  1. #41 Re: Starting Hptuners
    Jul 2008
    Tampa, FL
    Quote Originally Posted by TheOtherNick View Post
    If your car wont shift WOT then you need tq mangament in the shifts, what timing table are you asking about? I zero out the temp modifiers so that it is just what I command it all the time.
    so if my car shuts off at wot from 1-2, should i enable tq mgmt?
  2. #42 Re: Starting Hptuners
    Charles City, IA
    It should never shut off.
    SMGPFC Two Nipple General
  3. #43 Re: Starting Hptuners
    Panama City Beach, FL
    Nope, the rev limiter is kicking you off.
  4. #44 Re: Starting Hptuners
    Moore, Oklahoma
    Just curious, what version software are you using? 2.22 or Beta 2.23?
    Thanks!
    Shawn W. Larsen
  5. #45 Re: Starting Hptuners
    Tq management is good?
  6. #46 Re: Starting Hptuners
    Buffalo
    Torque managment will pull power during a shift which a stock trans needs, with this turned off you are pushing more power through a trans that doesnt want it and causing the shift to take longer.* Im concerned with my new built trans because as it may seem okay now, I'm guessing the sloppy 1-2 shift problem will appear again down the road
    I tried to obtain a general consensious of how to set up my 03 regal trans tables on the hpt forum but no bites as of yet
  7. #47 Re: Starting Hptuners
    Torque managment does no such thing. It is a preventative measure designed to protect weak drivetrain components. GM wasn't stupid, just cheap. On another note each and every rebuilt performance tranny I've ever installed required fine tuning to achieve desired results, no patter what. No two transmissions will respond exactly the same to a particular tune.
  8. #48 Re: Starting Hptuners
    Buffalo
    It does no such what? Your reply seems to agree with my last post but not sure if u are saying tm is needed or not?
  9. #49 Re: Starting Hptuners
    Quote Originally Posted by crazyguy03 View Post
    Torque managment ...with this turned off you are pushing more power through a trans that doesnt want it and causing the shift to take longer
    It does not cause the gear change to take longer- When you exceed the amount of power the clutch frictions/steels and band/drum assembly can hold, you get slip. This has nothing to do with TQ MGT causing the shift to delay. No different than trying to hook a high whp car on radials vs. slicks.
  10. #50 Re: Starting Hptuners
    Buffalo
    Well should I enable tm now on my new build to avoid having the sloppy shifts later on down the road from having it disabled? I talked to mr Norris that's what he recommended you more than welcome to check my tune. I use beta
  11. #51 Re: Starting Hptuners
    No, I'd not re-enable Tq Managment, as again, it's based on a set of default values for a stock powertrain. I'd adjust apply rates and line pressure via EPC to find a happy medium between driveability, shift firmness, and parts durability. Seat of the pants, real street tuning here cannot replaced by a mail order or dyno tune. If you take nothing else away from this, remember, EVERY combo is different.
  12. #52 Re: Starting Hptuners
    SE Level Member myfirstbonnie's Avatar
    Hillsboro, Oregon
    To add fuel you will need to add to the table by multiplying by 1.02, if you need to pull fuel you need to multiply by -1.02. Remember we are only scaling from 7000hz up in the maf table like so.
    I just got my HPT software and have been following this thread and everything is good so far. The problem I am having is the factor to multiply by when running rich. I am using an AEM WB and needing to lean out for my WOT runs. If I multiply by the -1.02 as stated, it puts all the cells to zero. If I do the 1.02 it increases it as it should.
    Should I actually multiply by .98 to get a small decrease in fueling.
    3 Bonnevilles:
    1989 LE 3800, 1992 SSEi, 2000 SSEi
    2004 GMC Sierra 2500HD
  13. #53 Re: Starting Hptuners
    Charles City, IA
    Yup.
  14. #54 Re: Starting Hptuners
    What do you think about Russ K's MAF tuning method?
    Seems to be much more effective than using fuel trims to adjust fueling.
  15. #55 Re: Starting Hptuners
    open loop for the beta guys that have a WB is great for fuel tuning... I haven used trims for a while to be honest...
  16. #56 Re: Starting Hptuners
    Open loop scares me.
    And IMO not worth my time.
  17. #57 Re: Starting Hptuners
    ^^^why?
  18. #58 Re: Starting Hptuners
    Because I drive under 7k a year and its not worth my time to learn it and do a bunch of junk I'll never use.
    Quincy, Mass
    I was nervous about tuning, open loop is about as easy as it gets. There is a great write up Russ k on hpt forums for open loop maf tuning. It takes half a day if that to get dialed in. Once your done you plug the narrowband back in and your good to go, you can fine tune your fuel trims after if you want but if you did the open loop right, kinda hard not to, they should be pretty close already.
    No more GP 04 Impala SS Indy:
  20. #60 Re: Starting Hptuners
    Topeka, KS
    Open Loops pretty simple really. Just a few more additional steps.
  1. looking at hptuners
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 03-14-2010, 10:30 PM
  2. HPTuners question
    By vailskier3 in forum PCM Tuning
    Last Post: 03-08-2010, 07:24 AM
  3. somebody with HPTUNERS or a programmer?
    By GTPJOE90 in forum PCM Tuning
    Last Post: 06-12-2009, 10:06 AM
  4. Hptuners
    By minichopper6hp in forum PCM Tuning
    Last Post: 06-07-2009, 01:26 PM
