this guy around here has HPTuner and he told me that the company told him he isnt able to do a case learn on my car? But isnt that what most of you guys use. I have an 01 Grand Prix GTP
Do you think he is just yanking my chain?
Odd...but I've had a similar issue before. When you come across an OS ID that isn't in the system, you send them the file and they make you a beta software version that you load.
On that beta version I once had an issue that the case learn piece was reading 100F degrees less. Therefore it never saw minimum temp to case learn.
I loaded back to the normal version and was able to do it. Then went back to beta to write to teh car.
When its cold like it is now(40*or below) my car stays at only a couple notches above 160 never get really hot
that could easily be the issue. Case learn requires the car to be at a certain temp.
You can get into more difficulties if its reading in C so its running at 80 C and then the thing looks for the number 100, doesnt care what units.
He straight up said they said dont support my car this is what he sent back because i wanted to try to use my stock pcm to see if it no longer need the case learn
we dont need credits as I can use tunercat to flash I don't prefer hptuners. also check if efilive can do your car. we have that also and don't need cred
its for efilive we have the unlimited version.
lulz.
because HPT does support our cars...
case learn is in the scanner function, doesnt have anything to do with flashing
Everything i have told him i know Copper is in The same town im in im going to hook up with him hopefully and see if he gives it a try for me because i really dont want to put the stock PCM back in i like how this one drives. So you dont have to buy credits to do the Learn tho right i think thatst wha t someone said
