Thread: XP cam tuning HELP!
Results 1 to 11 of 11
  1. #1 XP cam tuning HELP!
    Banned
    Sioux Falls, SD
    Im am going to be tuning my car this week after it gets built, and i need some assistance, It is a 2007 GP. Here are the list of mods
    1. XP Cam
    2. 42.5 LB injectors
    3. Double Timing chain
    4. Input shaft
    5. 7/8 3.29 Trans Chain
    6. Shift kit (not trans go)
    7. Headers
    8. 180* T-Stat
    9. Wizaird Intake
    10. Lightly ported heads
    11. Blocked coolant ports
    12. 105 Springs
    13. EGR Delete
    14. Wideband
    Any help would be greatly appricates
  2. #2 Re: XP cam tuning
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    You will need the correct IFR table. And to do a maff tune. Oh and I hope you have a wideband
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: XP cam tuning
    And take it easy.
    get part throttle solved before you get further in it.
    And you had better have a wide band.
  4. #4 Re: XP cam tuning
    Banned
    Sioux Falls, SD
    Yes i ordered a Wideband
  5. #5 Re: XP cam tuning
    Banned
    Sioux Falls, SD
    Quote Originally Posted by 01gpgt01 View Post
    Where would i get this?
  6. #6 Re: XP cam tuning
    Hagerstown,Md
    The maf tune your gonna need to do yourself from logs if you have a tuner, Otherwise find someone or try a canned tune. You might find one in the tune repository on HP tuner if you have a HP tuner. The IFR table 42.5 Injector Table (IFR KPA)
    47.34535 47.89466 48.57452 49.53676 49.73570 49.84055 49.90750 49.97463 50.04195 50.21587 50.37149
  7. #7 Re: XP cam tuning
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    tuning is just to much lol. its to much to rememeber and its alot of numbersssss
  8. #8 Re: XP cam tuning
    Banned
    Sioux Falls, SD
    I have a DHP tuner.
  9. #9 Re: XP cam tuning
    Hagerstown,Md
    Main Page - OpenTuner Notebook Skip the VE tune section
  10. #10 Re: XP cam tuning
    Banned
    Sioux Falls, SD
    Ok so i got my injecotor flow rate figured out, and i dont need to touch my maf cause its the same as before. now i need help with timing. I am very stummped on this one.
  11. #11 Re: XP cam tuning HELP!
    BonnevillePRO.com • View forum - Tuning
    Tons of stuff and bins. If you don't see bins with some of the stuff you need, holler I probably have it and haven't posted. Search for gearing and my SN and you'll find the gear changes etc.
  1. Tuning Help!
    By Kejross in forum Southwest
    Last Post: 03-15-2011, 11:45 PM
  2. Looking for help tuning
    By 2000 Black 2dr in forum PCM Tuning
    Last Post: 07-02-2010, 08:09 AM
  3. Pcm tuning
    By Ttypel67 in forum PCM Tuning
    Last Post: 06-21-2010, 11:01 PM
  4. Tuning?
    By 04gpking85 in forum PCM Tuning
    Last Post: 11-25-2008, 11:28 PM
