"""""""READ EVERYTHING BEFORE POSTING"""""""
My car= 2002 40th edition grand prix n/a (93 octane is used every fill up)
Ok as stated above i need help creating a list for my custom tune that i am ordering from intense racing. Just for some basic info this is what my build is. Parts are in the process of being acquired.
-Cone intake on TB (installed)
-Speed Daddy headers
-No CAT or rear O2
-Aftermarket DynoMax mufflers (installed)
-ZZP HV3
-180* Drilled thermostat
---------Things i would like-----------
-No EGR (status as ready so i pass inspection)
-No EVAP (status as ready so i pass inspection)
-No rear O2 (status as ready so i pass inspection)
-Best WOT ignition timing possible for my build
-No speed limiter
-Good shift points
-Increased trans pressure
Add anything else you guys think would be good
Im buying the PCM early so after its all installed i can just pop in the new PCM.
Just as a side note im starting this thread early so i can get everyones input on what the list should be so i get the most out of my PCM. Also all DTC's need to have a ready status and thats whats worrying me the most so please help me make the right list.
All will be done after making an appointment with Uncle Bill ROFL!!
