Thread: race fuel
Results 1 to 12 of 12
  1. #1 race fuel
    i have a question that prolly sounds dumb but i need to know if i can run leaded race fuel through my gtp or if it will mess anything up or if i need to find unleaded race fuel
  2. #2 Re: race fuel
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Leaded race fuel will ruin your O2 sensor, I am not sure if it will hurt anything else though.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  3. #3 Re: race fuel
    Bastard Reptile's Avatar
    Kansas City, MO
    If you dont need to run race fuel....then don't. Much less leaded. IT will kill the O2 sensor before you hit the traps.
  4. #4 Re: race fuel
    im goin to be doin some 100 foot drags with the local guys and ill be tuned for race fuel can i use a bunch of octane boosters and have same effect when i used octane boosters before it didnt seem to help much
  5. #5 Re: race fuel
    Donating Users blowfishRus6's Avatar
    g.a.
    QUESTION...if you use higher octane, racing fuel...will the pcm up the timeing for the better fuel???
  6. #6 Re: race fuel
    Kansas City, MO
    Quote Originally Posted by 1badgp View Post
    The only octane booster that is worth a poo is Torco...but again...if you tune a car on 91, then you aren't going to gain anything by putting 100 in it...period
    Quote Originally Posted by blowfishRus6 View Post
    It will only go to the max value that the timing tables are set to....so if it's set to 15* of timing, that's all it's going to do.
  7. #7 Re: race fuel
    g.a.
    okay, but on a hot day when timing starts to get retarted, would race fuel make up for that?? im just wondering if i go to the track in the summer time if race fuel would make up for it
  8. #8 Re: race fuel
    TDCRacing
    Guest
    Really the only reason the pcm would retard timing in hot weather would be because the iat was reading 104* or above. In this case, no race fuel would not help only iat readings below 104*
  9. #9 Re: race fuel
    g.a.
    ahhh okay. thats what i was wondering
  10. #10 Re: race fuel
    SE Level Member TehGTP's Avatar
    May 2008
    Saint Louis, MO
    i ran leaded 110 in a 50/50 mix for a couple weeks and the car ran great(less kr), but shortly after that i replaced my factory o2 sensor
    and this is what it looked like.
    http://webpages.charter.net/rkneibert/GTP/12.JPG
    2007 Corvette Z06 - BFD Cam / E85 / milled & fixed heads
    2006 GTO M6 18's - SOLD - VRX5 Cam | FAST 102 | Exhaust
    2001 GTP - SOLD - 1.9 | TOG's | E85 | LC1 | B+G | AGX | GMPP | 3EP
  11. #11 Re: race fuel
    May 2008
    McHenry IL
    i drink leaded racing fuel soo what?? im still alive lmao jk
  12. #12 Re: race fuel
    Apr 2008
    upton ma
    100 oct unleaded in great
    2003 gtp sedan blk on blk -motorsports cai- 3.5 zzp mod . aero force gauge-intense standard pcm w raise shift points and more timing- 180 stat. ss plog -2.5" dp-autolite 104s
  1. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  2. I got to drag race for the first time sunday!!
    Last Post: 06-09-2008, 11:00 AM
  3. funny race
    By stlmo_gtp in forum Track Sessions and Kills
    Last Post: 04-10-2008, 11:13 AM
  4. 2000ish bmw 540i mini-race
    By fst in forum Track Sessions and Kills
    Last Post: 02-10-2008, 09:54 PM
