Thread: tune advise
Results 1 to 20 of 30
  1. #1 tune advise
    GTX Level Member Juanmiguel's Avatar
    Mexico
    So I just recently went cammed and droped to a 3.25 pulley. Now I'm in the process of acquiring a DHP power tuner (thanks Bbptech). I've also been reading the wiki page stickied in this section on how to do a VE tune.
    My question is, given that I'm planning on using a basic DHP tune as start point. In order to adjust the tune to accommodate the new mods, do I need to modify all the tables (VE, MAF, timming and O2) or just a couple of them like O2 and timing?
  2. #2 Re: tune advise
    Bastard Reptile's Avatar
    Kansas City, MO
    Concentrate on one table at a time.....watch your fuel trims, and your KR. If you're positive on the trims too much, you need to add fuel, subtract if the trims are too negative. +/- 4 is your goal, and make sure when you're in PE mode they lock in at 0.0
    The first thing you should do, is find the section in your timing that is where your WOT timing will be, on the DHP it is usually the bottom portion of the timing tables where it's lowest. Pull about 6* out of that to keep things down at first until you get the fueling taken care of.
  3. #3 Re: tune advise
    Jan 1970
    Maquoketa, Iowa
    Most people skip the VE tune. You can try it, but it's not the easiest and most productive way to start.
    Get on the powrtuner forum right away after you get the serial # from the powrtuner to get access to the downloads section. Make sure you have all of the .net and keyspan drivers downloaded. Download UVscan and use that for scanning. Download Eddies table modifier and use that for maf tuning, do not do too much at one time like Reptile said.
    One of the most important parts is learning how to get a good scan. Going WOT right away will not get you anywhere. You want to start small and work your way up the maf table, if your tuning via fuel trims and maf table, it would be a good idea to disable PE and never go WOT with PE disabled. This means slow, easy cruising going through various throttle positions very slowly. A scanner does not collect data in real time and the slower you go the more info. that can be gathered and analyzed. After getting a good scan and either using eddies table modifier or manually changing your maf table, make small changes and then upload and reset the fuel trims when playing with fuel tables.
    Once you have reset the trims, it really does take up to 30 minutes of driving through various throttle positions and restarts sometimes for them to re-learn. If you start logging before the fuel trims are learned, it may not help your next change or throw things off. Then repeat enough times and slowly work up to 60% throttle or until you see some knock, well at anytime if you see 2+ degrees of knock, stop and back off some timing/pulley down. After you have things pretty well figured out, enable PE. This should get your maf chart dialed in pretty decent.
    After that it is WOT tuning and this is where a wideband comes in very handy.
  4. #4 Re: tune advise
    Mexico
    thanks guys i'll keep all this in mind. I'll see how it works out once I start working on the tune.
  5. #5 Re: tune advise
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    VE tune is worthless. Do yourself a favor and get a wideband. No use in guessing WOT fueling.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: tune advise
    Mexico
    Ok so I'm at my 4th pass tunning the VE table. I still see 2 digit numbers in my fuel trims at idle, besides that I can say it's fairly between +- 10 when moving.
    Should the trims also be between -4 and 0 at idle?
    I'm not sure how many passes should I be doing, seems like getting the trims between -4 and 0 will take a long time.
    I'm using the table modifier thing at 50% and using ltft and stft for calculation with 3 hit counts or more.
  7. #7 Re: tune advise
    Mexico
    this is the adjustments from the modifier out put. I guess the trims are in the positive numbers in average, although i'm not sure if the quantities added are enough to make a significant difference in the trims:
    MAP kPa|RPM Cell|Old Value|Average FT|Adjustment Amount|New Value|Hits
    20 0 0.3688965 0 0 0.3688965 4275
    20 1600 0.514079 1.603618 0.006182899 0.5202619 19
    20 2000 0.5212091 -0.1420455 -0.0005552653 0.5206538 11
    20 2400 0.5196945 -1.450893 -0.005655157 0.5140393 7
    20 2800 0.5167581 -4.296875 -0.01665334 0.5001047 6
    30 800 0.5020993 0.4261364 0.001604721 0.503704 11
    30 1200 0.5450789 -0.0813408 -0.0003325286 0.5447463 413
    30 1600 0.5679294 0.940534 0.004006177 0.5719355 103
    30 2000 0.572019 1.367188 0.005865429 0.5778844 16
    40 800 0.5320979 2.154216 0.008596903 0.5406948 507
    40 1200 0.5746939 6.960227 0.03 0.6046939 132
    40 1600 0.6126699 4.862608 0.0223438 0.6350137 58
    40 2000 0.622858 5.989583 0.02797995 0.650838 21
    50 800 0.5596333 3.90625 0.01639551 0.5760288 22
    50 1200 0.6185703 6.933594 0.03216687 0.6507372 16
    50 1600 0.6493966 5.380155 0.0262039 0.6756005 97
    50 2000 0.6775228 4.427083 0.02249587 0.7000186 24
    60 1200 0.6116282 5.902778 0.02707729 0.6387055 9
    60 1600 0.6629663 3.515625 0.01748056 0.6804469 24
    60 2000 0.6825233 4.805425 0.02459861 0.7071219 53
    60 2400 0.7000269 3.359375 0.0176374 0.7176643 10
    70 1600 0.7215499 8.258928 0.04469422 0.7662442 14
    70 2000 0.7101685 6.008732 0.03200409 0.7421726 68
    70 2400 0.7260638 5.553668 0.03024238 0.7563062 46
    70 2800 0.7044055 4.785156 0.02528018 0.7296857 8
    80 1600 0.7561182 4.947917 0.02805907 0.7841772 3
    80 2000 0.7057804 5.829327 0.03085669 0.7366371 13
    80 2400 0.7378831 4.744318 0.02625564 0.7641388 55
    80 2800 0.7602965 3.125 0.01781945 0.778116 10
    80 3200 0.7661721 4.947917 0.02843217 0.7946043 3
    90 2000 0.7744392 6.705729 0.03894885 0.813388 12
    90 2400 0.7730451 2.709961 0.01571191 0.788757 64
    90 2800 0.7689871 1.204427 0.006946417 0.7759336 24
    100 2400 0.7757413 6.054688 0.03522653 0.8109678 8
    100 2800 0.7895724 1.192434 0.007061348 0.7966338 38
    110 2800 0.807003 3.385417 0.02049031 0.8274933 24
    110 3200 0.7903881 2.929688 0.01736693 0.8077551 8
    120 2800 0.8211598 0.5208333 0.003207655 0.8243675 6
    130 3200 0.8068758 1.71875 0.01040113 0.817277 15
    130 3600 0.7944646 3.28125 0.01955128 0.8140159 5
    130 4400 0.7977614 3.385417 0.02025566 0.8180171 3
  8. #8 Re: tune advise
    Hagerstown,Md
    Why are you VE tuning. Its a waste.
  9. #9 Re: tune advise
    Hagerstown,Md
    Way I always did my LFT's Was I used maf Hz Vs Lft. I would then add or minus according to where the Lft's were off on the HZ scale. I can usually get close on one shot now after doing a few
  10. #10 Re: tune advise
    Feb 2009
    flintnasty MI
    When in maf fail mode, the LTFT area is not reporting readings from the o2 sensor as much as it is just adjusting the afr based on conditional situations, such as intake air temp, engine coolant temp, and a few other params.
    Not only does the "ve tune" go away when you plug the maf back in, it also is impossible to do using LTFT (aka the narrowband sensor).
  11. #11 Re: tune advise
    Mexico
    I have a few scans from different VE tables, I'm going to do a manual adjustment using whatever value in a specific cell resulted in an average -3 to 0 fuel trim and see if it that gets me closer to the target.
  12. #12 Re: tune advise
    Hagerstown,Md
    Are you talking about the Primary VE VS RPM VS Map table? If so Making changes will not do ANYTHING
  13. #13 Re: tune advise
    Hagerstown,Md
    You need to make adjustments in the Maff airflow frequency table.
  14. #14 Re: tune advise
    Mexico
    I was wondering myself why would I need to tune the VE table and I came across a write up on how to tune VE tables for LS1 engines and it said the following:
    "So, if we have a
    MAF, why do we have a VE table at all? One thing the VE table does is provide a
    reference airmass calculation. The PCM uses this reference to compare the measured
    airmass supplied by the MAF to so it can ensure that the MAF is operating correctly.
    Also, while the MAF is accurate at measuring airmass that is entering the engine at a
    constant rate, it is not at all accurate when the airmass is changing, like during throttle
    transitions during normal driving. At these times, the PCM blends the MAF signal with
    the airmass calculations derived by the VE table to provide accurate fueling. So, above
    4000 RPM, or during steady MAP conditions, fueling is set using the airmass
    measurement provided by the MAF alone. Under 4000 RPM, during unsteady MAP
    conditions, fueling is set using the airmass measurement provided by the MAF, modified
    by the airmass calculation derived from the VE table. Understanding the close interaction
    between the MAF and VE table, it is easy to see why it is important that they both are
    correct and working together."
  15. #15 Re: tune advise
    Hagerstown,Md
    That Does not Apply to us. Our cars ONLY referance this table when the maf fails. You could Zero the table out and it wouldnt do anything. Many have done it as a test.
  16. #16 Re: tune advise
    Mexico
    yes i was talking about the RPM vs MAP table. It's the first time I'm doing a custom tune, I'm just following a couple of guides on how to.
  17. #17 Re: tune advise
    Mexico
    crap... so I should just leave the VE table as is and move on with the MAF table?
  18. #18 Re: tune advise
    Mexico
    Quote Originally Posted by 01gpgt01 View Post
    Lol then I guess I'll have no problems running my car if that ever happens XD.
  19. #19 Re: tune advise
    Hagerstown,Md
    Quote Originally Posted by Juanmiguel View Post
    you got it. Start with the cruise Maf Hz range thru 7500. Then when you get them dialed in move into the WOT hz ranges. Also with your mod level you should be widebanding so you can dial in your WOT ranges. Even with my 02's in the 910 range I was at 10.8 afr! Im sitting at 865-870 02's Wot with a afr of 11.7
  20. #20 Re: tune advise
    Mexico
    all right then. I guess I'll leave it like that then, it was getting close to 0 ltft anyways. Thanks!
  1. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  2. Looking for some advise
    By o0DarkHaven0o in forum General Tech Discussion
    Last Post: 05-23-2010, 09:31 PM
  3. need advise
    By boothe in forum Off Topic Discussion
    Last Post: 05-09-2010, 05:13 PM
  4. **NEED ADVISE** please help
    By tmackster in forum General Tech Discussion
    Last Post: 05-05-2010, 10:40 PM
  5. Some Advise Please
    By Scott B in forum General Tech Discussion
    Last Post: 04-19-2008, 01:08 PM
