Thread: Jerry's Tuner Notebook -> Wikified
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 96
  1. #21
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by shor0814 View Post
    And the first thing you will notice, the max value for RPM vs ECT is 1200...which won't match the settings for Jerry's tune.
    Not a huge deal, because most tunes won't have an XP cam and need a higher RPM, but still....
    You will also find that some of the newer (2002) binfiles have extra options for A/C on and off too. I guess we have LOTS of work ahead to support both tuners.
    1200 rpm should be fine. I have an XP and can't imagine why a desired rpm of more than 1200 at any ECT would be needed.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
    Aurora, Colorado
    Quote Originally Posted by IndeedSS View Post
    I don't know if anyone needs a higher RPM, but my point was, if anyone wanted to follow the PT guide, they wouldn't be able to replicate Jerry's RPM values.
    The other problem, which program has the correct max value.
    St Louis MO
    Your best bet is to check over at the HPTuners site. Chris, Keith or Bill will tell you what the code shows. However as we already know, like why VE tuning works on some V6 cars and not on others, it may depend in the OSID as to the max value. Evidently there are over 500 OSID's for the V6 crowd.
    In case it was missed, there is a table were you can essentially turn on or off the VE references. Even though we can't see it YETSome of the OSID's have this turned on and some don't...that table should be in the HPTuners next release.
    2010 Camaro SS LS3
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    oooo. hadn't heard that... is that just true with the pre 04 or is that still true with the new ones as well?
    Aurora, Colorado
    Already let them know about it. They are looking into it.
    Quote Originally Posted by TyroElite
    I think they are still figuring out exactly how the table works and what cars have it. Even after all these years, there are still magic tables to be found.
  6. #26 Re: Jerry's Tuner Notebook -> Wikified
    GT Level Member japslpr's Avatar
    VA Beach
    Now, on top of this, O2s will be different in a Texas summer versus a Canadian winter. Because of the much colder winter air, I can get away with running a much leaner (lower O2 readings) in the winter than the summer. Taking my car as an example (Supercharged (or turbocharged) cars with an aftermarket cam) I say that 920-935 O2s are good. In the winter, on the same car, I could easily go down to approximately 915-925 without any increase in KR. If you live in a hotter climate, you may need to add 10% to the O2 numbers that I suggest. These are approximate O2 numbers and nothing is set in concrete... your car, tune and KR numbers will ultimately dictate what A/F ratio your car runs best at.
    I have a question about this statement.
    Wouldn't you want to run a little leaner in the summer and richer in the winter as colder air is more dense than warm air.
    Cold Air = More Oxygen which = more required fuel (richer)
    Hot Air = Less Oxygen which = Less required fuel (leaner)
    Jae Harris: 1999 GTP, PARTED OUT
    1997 GTP: K&N 9", Stage 3 Gen 3, ZZP Hub w/ 3.25, S/S Headers, T&D Split Ratio RR (I-1.6, E-1.7), DHP 1.0, BEAR Big Brake Kit, 17x9 Cobra R's, GMPP Strut Towers F/R, Stage 1 Custom Cam
  7. #27 Re: Jerry's Tuner Notebook -> Wikified
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Thanks for doing this. This is great info and help.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  8. #28 Re: Jerry's Tuner Notebook -> Wikified
    Oklahoma
    Indeed it is. Also, for those doing the Wiki, I found the link to an open source tuner for the Subaru's if you are interested. I thought someone was looking for it and it took me a while to get it since the site was off line. But its back now and I literally just got the link yesterday.
  9. #29 Re: Jerry's Tuner Notebook -> Wikified
    St Louis MO
    Quote Originally Posted by japslpr View Post
    I thought the same as you Jae. That's the reason it's so easier to chip a piston on a real cold day in the winter.
    2010 Camaro SS LS3
  10. #30 Re: Jerry's Tuner Notebook -> Wikified
    St Louis MO
    Quote Originally Posted by TyroElite View Post
    As I understood it it was random for now. Perhaps once the table is accessible to everyone, a pattern will emerge.
    2010 Camaro SS LS3
  11. #31 Re: Jerry's Tuner Notebook -> Wikified
    I've already started a HPT version of this guide and when it is ready, I will release it. I wrote this guide several years ago and since then quite a lot has changed/expanded and what not. I received my HPT early this year, but work and life in general have kept me so busy, I hardly have time for a breath... but it is in the works, and it will be far better than this one, with info specific to the HPT.
    Keep your eyes peeled later on this summer/fall for the new later, greater JerryH tuning guide.
    In the meantime, if you guys feel like repeating work that I will be doing anyways, feel free to do so.
  12. #32 Re: Jerry's Tuner Notebook -> Wikified
    Just wanted to prove that the skeleton and a lot of the info is already in place. The rest is to come as soon as I have the chance.
    Note the all new videos and occaissional tunes sections!
  13. #33 Re: Jerry's Tuner Notebook -> Wikified
    PA
    Quote Originally Posted by JerryH View Post
    Note the all new occaissional tunes sections!
    Does this include the wife/gf tune? haha...
    2001 GSE
  14. #34 Re: Jerry's Tuner Notebook -> Wikified
    Quote Originally Posted by Zef_66 View Post
    Some ideas:
    The Friend tune
    The parent tune
    The G/F tune
    The valet tune
    The GM mechanic tune
    ... and more.
  15. #35 Re: Jerry's Tuner Notebook -> Wikified
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    I just found this what a great idea I have held off getting a turner because I have so little knowledge of what to change. Some ideas on what I would be looking for and what to change to get them right TKS
  16. #36 Re: Jerry's Tuner Notebook -> Wikified
    Oct 2008
    Northern Illinois
    Is there such a thing as an open source tuner for a GP?
    Or at least a scan tool?
  17. #37 Re: Jerry's Tuner Notebook -> Wikified
    PA
    Quote Originally Posted by BwolfGT View Post
    Scan Tool
    UVScanning.com
    2001 GSE
  18. #38 Re: Jerry's Tuner Notebook -> Wikified
    Oct 2008
    Northern Illinois
    Where can I get the OBDII to USB cable cheap?
  19. #39 Re: Jerry's Tuner Notebook -> Wikified
    Bunnell, FL
    Making a choice on your wedding day is a professional photographer ...
    someone edited your **** sir
    I'm a Sex Offender
  20. #40 Re: Jerry's Tuner Notebook -> Wikified
    This sucks
