Really dumb/newbish question, but how does the PCM read the IPWs? Is it at the point of the injectors spraying, point of fuel entering the combustion, or after it leaves the exhaust valves? Reason im asking is because since im running alky, my IPWs are spiking to 21mS on stock injectors with the 3.2” pulley running 18* of timing. My wb is also at 10.5 but after talking with a few alky users, that’s where I should be at. I asked a few members and they say usually when running 3.0” pulley is when the stock injectors are maxxed. If the IPWs are read at the injectors spraying then my tune is bad and needs a better tune.
