Thread: Disabling Cat Diagnostics
Results 1 to 14 of 14
  1. #1 Disabling Cat Diagnostics
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. Is HP Tuners capable of disabling cat diagnostics on 01+ cars? If not, what will? Tiny Tuner?
  2. #2 Re: Disabling Cat Diagnostics
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Spark plug non foulers work
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Disabling Cat Diagnostics
    I wanted to replace that O2 sensor with a wideband. Won't be possible?
  4. #4 Re: Disabling Cat Diagnostics
    Hagerstown,Md
    Quote Originally Posted by Bedwards View Post
    I did that with mine and I have not had any issues. If you have hp tuners just uncheck ses enable on the po420 dtc. See if you start getting 16.4 lfts when you are at a cruise or idling. if you do chances are you will need to rerun the rear 02
  5. #5 Re: Disabling Cat Diagnostics
    Quote Originally Posted by 01gpgt01 View Post
    I did that with mine and I have not had any issues. If you have hp tuners just uncheck ses enable on the po420 dtc. See if you start getting -16.4 lfts when you are at a cruise or idling. if you do chances are you will need to rerun the rear 02
    Your fuel trims were fine when you did that?
  6. #6 Re: Disabling Cat Diagnostics
    Hagerstown,Md
    Yep. its been about two months with no issues
  7. #7 Re: Disabling Cat Diagnostics
    Replaced the rear O2 with my wideband in my 01 Grand Prix GT. Fuel trims were unchanged. The cat diagnostic must only react on 01+ GTP's (not GT's, as both me and 01gpgt01 have GT's with no problems).
  8. #8 Re: Disabling Cat Diagnostics
    Charles City, IA
    Mine is one of the freaks that runs fine with out it.
    SMGPFC Two Nipple General
  9. #9 Re: Disabling Cat Diagnostics
    you have a wideband in your rear o2 sensor bung after the cat?
  10. #10 Re: Disabling Cat Diagnostics
    Charles City, IA
    I am assuming he did not install a cat with his speed daddys and is just using the extra bung in the rear.
  11. #11 Re: Disabling Cat Diagnostics
    Outer Space
    Bedwards I was a victim of the 16.4 issue. If you can load a bin file into hptuners...let me know I got a fix. Mines a 2002 btw.
    02 GTP 13.6 @ 100mph - SOLD
  12. #12 Re: Disabling Cat Diagnostics
    SE Level Member gtpracer0186's Avatar
    Apr 2008
    Joliet, IL
    I have the same problem, what did you do to fix it?
    Thanks
    2001 GTP......3.4, 3.5 mps , 180* T-Stat, DHP v1.0 PCM, Autolite 104's, zzp stage 1 TB, TB spacer,TB heat shield, Custom FWI, Front P-Log ceramic coated crossover, zzp 2.5" downpipe to custom exhaust, D/S rotors, Alt Rewire,Ported supercharger, machined intake, 1.9 modified rockers. Sd Headers, Hp Tuners!
  13. #13 Re: Disabling Cat Diagnostics
    Yes, however I don't have a cat, I have headers.
    Correct.
    Quote Originally Posted by Lawngoose View Post
    Quote Originally Posted by gtpracer0186 View Post
    Thanks
    I didn't adjust anything. I don't even have my HP Tuners yet (should arrive anyday though ). I have an Intense custom mail-order tune right now with the option "Disable rear O2 sensor DTC's" selected. I took my rear O2 out, and replaced it with the wideband. Car runs perfect and fuel trims are exactly the same.
  14. #14 Re: Disabling Cat Diagnostics
    Jan 1970
    Maquoketa, Iowa
    You can disable it in Tiny Tuner. I'm not on here or don't have much time to post here anymore, but it is possible in Tiny Tuner. Look in diagnostics> cat diagnostics and set the cat diagnostics to 0.
  1. tcc lockup disabling???
    By 513yj in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-18-2009, 10:08 AM
  2. Professional Installs, diagnostics and maintenance PA
    By silvermistwbody in forum Northeast
    Last Post: 07-27-2009, 09:30 PM
  3. Diagnostics on a Head Unit
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 02-27-2009, 10:39 PM
  4. disabling DRL's?
    By TJs97 in forum General Tech Discussion
    Last Post: 09-10-2008, 11:18 PM
