Hey guys. Is HP Tuners capable of disabling cat diagnostics on 01+ cars? If not, what will? Tiny Tuner?
Spark plug non foulers work
Replaced the rear O2 with my wideband in my 01 Grand Prix GT. Fuel trims were unchanged. The cat diagnostic must only react on 01+ GTP's (not GT's, as both me and 01gpgt01 have GT's with no problems).
Mine is one of the freaks that runs fine with out it.
I have the same problem, what did you do to fix it?
Thanks
Yes, however I don't have a cat, I have headers.
Correct.
I didn't adjust anything. I don't even have my HP Tuners yet (should arrive anyday though ). I have an Intense custom mail-order tune right now with the option "Disable rear O2 sensor DTC's" selected. I took my rear O2 out, and replaced it with the wideband. Car runs perfect and fuel trims are exactly the same.
You can disable it in Tiny Tuner. I'm not on here or don't have much time to post here anymore, but it is possible in Tiny Tuner. Look in diagnostics> cat diagnostics and set the cat diagnostics to 0.
