I got a P0171 code after installing 39# injectors
I changed the IFR based on 31/39=.794871
So, Table/0.795=NewTable
Am I wrong?
Did I have 36# injectors?
Is it just my trims are that far out of whack?
Am I wrong?
if you mis calculated the injectors to a higher rate you shouldnt be pulling a lean condition code
I thought 04+ were 36 lbs,
Ed morad lists them as 36, from his listing:
This sale is for a set of 6 good used factory 36 Lbs. flow fuel injectors. These will fit GM 3.8 / 3800 series III L32 supercharged engines.
The part number is 12574393. These are the blue / gray in color.
Well, I added 10% to the IFR Table
Trims were closer, did 1 MAF tune, trims look alot better
I'm about to update the MAF for the 2nd time tonight
We'll see where it goes
Okay,...
I took these threads to heart, and talked to a few people
I'm redoing my IFR Table with math for 36# vs. 39#
So, 92.3% change
Also, I back-up to my last MAF Table b4 I changed the FIs
We'll see where this leads me
