Thread: vac leak? cat diagnostic?
Results 1 to 6 of 6
  1. #1 vac leak? cat diagnostic?
    Jul 2008
    Tampa, FL
    I'm running an 05 pcm in an 07 GP n/a. Just installed headers yesterday. I've been trying to get this pcm running properly for about 2-3 months now, and i keep switching it back to stock (the 07 pcm cannot be tuned). I am running into the following issues with the 05...My fuel trims seem to be stuck at 16.4, but are not that way all the time. I am getting lots of KR (up to 8*) at medium throttle levels. I am wondering if someone can take a look at my scan. I have attached my scan and the tune that i have on the pcm. I also need some information on how to get out of VE tuning. I have heard that i should not be tuning with VE. I can't seem to figure out in the program how to change it. Am I having a vac leak? Is it just a cat diagnostic? Why am i getting less than 16mpg's on an n/a vehicle???
    here is a link to my scandepot page. todays scans are may92010-1,2,3. thanks!
    Scan Depot dot net
  2. #2 Re: vac leak? cat diagnostic?
    Jul 2008
    Tampa, FL
    oh, and here are the DTC's i'm getting with this 05 pcm FYI:
    [PCM] P0036 - HO2S Heater Control Circuit Bank 1 Sensor 2 (Immature)
    [PCM] P0131 - HO2S Circuit Low Voltage Bank 1 Sensor 1 (Pending) (Current) (Immature)
    [PCM] P0141 - HO2S Heater Performance Bank 1 Sensor 2 (Pending) (Old) (Current) (Immature)
    [PCM] P0412 - Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1 (SES) (Pending) (Old) (History) (Current) (Immature)
    [PCM] P0418 - Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1 (SES) (Pending) (Old) (History) (Current) (Immature)
    [PCM] P2432 - Secondary Air Injection System Air Flow/Pressure Sensor Circuit Low (SES) (Pending) (Old) (History) (Current) (Immature)
    [Unknown] B3948 - (History) (Current) (Immature)
    [Unknown] B3949 - (History) (Current) (Immature)
    [Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
    [Restraints] B0092 - PPS passenger detection error (History) (Immature)
    [HUD] U1000 - Class 2 Communication Malfunction (History) (Current) (Immature)
    Continuous Tests
    Misfire: Complete
    Fuel System: Complete
    Comprehensive Component: Complete
    Once Per Trip Tests
    Catalyst: Incomplete
    Heated Catalyst: n/a
    Evaporative System: Incomplete
    Secondary Air System: Incomplete
    A/C System Refrigerant: n/a
    Oxygen Sensor: Incomplete
    Oxygen Sensor Heater: Incomplete
    EGR System: Complete
  3. #3 Re: vac leak? cat diagnostic?
    Outer Space
    I wouldnt worry about the 16.4 until you get that exhaust leak fixed. It might not be the problem, but I was thinking about that today. Can't really tune when leaking.
    Those codes are all related to AIR/HEATER ... You did say your air does suck... hmm wonder why you didnt get that on 07 PCM.
    Also HPTuners... any of you have any advice/writeup on how he can do a MAF TUNE? I have a PT, so I am no help.
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: vac leak? cat diagnostic?
    Jul 2008
    Tampa, FL
    actually, when i started it up this morning, i threw an ses light on the 07 pcm...i'm assuming its the cat diagnostic you were talking about
  5. #5 Re: vac leak? cat diagnostic?
    Outer Space
    Quote Originally Posted by vailskier3 View Post
    Here is an link about it... the only reason I know about this.. is because I experienced it.. however, don't you have a scan before the header rear o2 delete? If so, does it show 16.4 too?
    http://www.grandprixforums.net/f65/r...ewer-7092.html
    An HPTuner thread I found regarding MAF Tuning:
    New tuner/ maf tune - HP Tuners Bulletin Board
  6. #6 Re: vac leak? cat diagnostic?
    Jul 2008
    Tampa, FL
    yeah, if you look at the march scan on the scandepot site, i had that scan done before the rear 02 delete...
  1. diagnostic ? on possable new ride to flip
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 05-04-2010, 09:59 PM
  2. odd leak... need some help
    By TLSheff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2010, 05:10 PM
  3. Removing/Disabling the Cat Diagnostic Test....
    By whitelightnin04MC in forum PCM Tuning
    Last Post: 06-13-2009, 12:26 PM
  4. I need diagnostic help!! PO502 and PO503 PLEASE
    By GTPOWER in forum General Tech Discussion
    Last Post: 08-01-2008, 07:07 PM
  5. MAF problem - need diagnostic help...
    By Boatman in forum General Tech Discussion
    Last Post: 05-25-2008, 10:21 PM
