Thread: tuning high MPH
Results 1 to 10 of 10
  1. #1 tuning high MPH
    SE Level Member deangtp's Avatar
    Kansas City, MO
    I know this is stupid and with recent events may be a sore subject but I have to know. I did a run the other day while scanning and got up to 131 and it shifted to 4th and then I had like 15* of knock. I'm sure it has something to do with TQ Man, but what is it that I need to look at. I was only getting maybe 1 or 2*'s before the shift.
  2. #2 Re: tuning high MPH
    TDCRacing
    Guest
    does this happen at all shifts or just when your going into 4th at those speeds?
  3. #3 Re: tuning high MPH
    you seriously let your car shift into 4th? wooooww..
    its knocking from a crazy high load in 4th gear.
  4. #4 Re: tuning high MPH
    TDCRacing
    Guest
    Yeah if it's happining ONLY in the 3 to 4 shift at wot that is why.
  5. #5 Re: tuning high MPH
    Kansas City, MO
    Just 4th gear. So what do I need to change in my programming?
  6. #6 Re: tuning high MPH
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    What does your fueling look like when this happens? Wideband numbers would be great but I know not many guys have one but they really do help out. As mentioned above 4th has a very high load on the engine, especially pushing a car into the wind at 130+ mph. Me and several other local guys used to do this often and I dont know of anyone that would have KR shoot up at all like that. Does the 15 deg KR stay there or was this only at the shift? Do you have a tuner or are you using a stock/shelp tune pcm?
  7. #7 Re: tuning high MPH
    Barksdale AFB, LA
    Quote Originally Posted by deangtp View Post
    Set the limiter to 120MPH.
    Okay, I'm sorry.
    2009 Subaru Impreza WRX STI
  8. #8 Re: tuning high MPH
    Kansas City, MO
    Uh. It was like 2* maybe and then the shift happened and it shot up to 6, 12, and then got up to 15 in the frames. I was scannnig but for some reason it didnt save it. My fuel injectors are maxed out. I saw 23.01 on the IPW's. My fuel trims are staying around .78 when I get in it though and it dont move around too much. So I was just looking at the program I have in there and it shows 130 on the 3-4 perf shift. Is that what i need to change. Also, Do I need to raise the RPM limiter or is that for regular drivng?
  9. #9 Re: tuning high MPH
    Fort Wayne, IN
    If your injectors are running that high of IPWs I would upgrade the injectors and retune the car before playing up at those speeds again! Without a scan its hard to see what is going on.
  10. #10 Re: tuning high MPH
    Kansas City, MO
    yeah i wish it would have saved but, ill get another one. I seen the 23.01 at the top of 3rd gear with almost 11000 HZ on the MAF. I know I need injectors and was thinking about those new SDD Fatman rails too. But how do I tune to go faster.
  1. HID high beam question.
    By Nabster in forum Visual/Body Modifications
    Last Post: 04-15-2008, 05:26 AM
  2. a little afc 2.2 tuning help?
    By Bio248 in forum PCM Tuning
    Last Post: 02-24-2008, 12:47 PM
  3. I'm looking for high resolution grand prix pictures
    By AlmightyBirdman in forum Off Topic Discussion
    Last Post: 02-21-2008, 08:56 AM
  4. high mileage trans issues
    By 01whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2008, 08:23 AM
  5. profanty filter set to high
    By chrisgtp in forum Forum Bugs/Suggestions
    Last Post: 12-29-2007, 12:11 AM
