Thread: Last nights scan
Results 1 to 7 of 7
  1. #1 Last nights scan
    Elk Grove Village, IL
    Im definatly lost. I was going by my scanmaster to monitor KR before. Needless to say it shows the LOWEST O2s and the HIGHEST KR on recall command. I for some reason thought it showed what your O2 was at the highest KR and thought I was running lean. This shows otherwise.
    4-14-08 Scan from Fish -- Scan Depot dot net
    Idle and cruise LTFTs are ****ing wack, but to me it seems WOT is pretty much spot on. Also, I know boost is calculated from the MAP sensor, but holy ****. 10lbs on a stock pulley.
  2. #2 Re: Last nights scan
    PA
    First thing you need to do is a VE tune and a MAF tune to get your trims under control. Doesn't matter what your 02s are right now. Get your trims correct and go from there.
    2001 GSE
  3. #3 Re: Last nights scan
    Here is a scan from last night to help see a bit more.
    4-15-08 Scan from Fish -- Scan Depot dot net
  4. #4 Re: Last nights scan
    PA
    Something isn't setup right on your tuner. Did you look at the scan at all?
    2001 GSE
  5. #5 Re: Last nights scan
    Actually, it wasnt like that on my laptop. Odd.
  6. #6 Re: Last nights scan
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    what is up with your timing?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  7. #7 Re: Last nights scan
    Right now the timing is stock.
    Heres a scan from yesterday.
    4-27-08 from Fish -- Scan Depot dot net
    Did some tweaking to the PCM and went for a short drive. The car pulled alot nicer. Max KR I saw was .9. Ill try to get a good scan tonight to compare.
  1. help with scan
    By ldyzluvdis06 in forum Midwest
    Last Post: 06-01-2008, 09:05 PM
  2. KR/scan tool
    By ldyzluvdis06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 10:24 PM
