Thread: Modifying stock bin file.
Results 1 to 3 of 3
  1. #1 Modifying stock bin file.
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Ok so im just gonna take it upon myself to tune my car and use the Jerrys Notebook tuning guide thing. With the bin preparation stage 1 part, can i set the same things he is setting in torque management? or is he setting all the torque management more for his car because XP cam? Im running a stock cam by the way if it matters.
    Also, if anybody could be of help and shoot me the tables for a 78mm TB, and 3.29 gears and where they would be added in on my PT program it would be much appreciated. Oh and where do i need to add for e85 and how much?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: Modifying stock bin file.
    SE Level Member almighty's Avatar
    northern illinois
    torque managment is the same for most all cars and you should be safe for removal of all the items similar to jerry. sorry about the rest of the stuff, im a bit new and working on alot of my own things with my dhp.
  3. #3 Re: Modifying stock bin file.
    Donating Users blowfishRus6's Avatar
    g.a.
    follow his torque management settings. there is some places where it cuts fuel to act as a limiter and that dangerious. as far as transmission torque settings, take it easy on those, they are they to help save your trans.
    i would just follow his advice.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  1. Modifying KYB Struts to Work with Coilovers.
    By pontiackid in forum How To Write-Ups/Tech Tips
    Last Post: 01-24-2010, 08:11 PM
  2. DHP file
    By TheOtherNick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-25-2009, 02:51 PM
  3. Needing a 00 SSEI bin file stock or NOT
    By glanzergtx in forum PCM Tuning
    Last Post: 05-13-2009, 11:42 PM
  4. Bought zz p bin file now...
    By GTP4 in forum PCM Tuning
    Last Post: 01-13-2009, 10:42 AM
  5. Need 1.5 Bin File for 2001 GTP
    By rynoman03 in forum PCM Tuning
    Last Post: 02-20-2008, 01:01 PM
