Thread: Injectors, what is the max duty cycle?
Results 1 to 5 of 5
  1. #1 Injectors, what is the max duty cycle?
    SE Level Member Stonewall's Avatar
    Rochester, NY
    Hi all,
    I was looking at some scans and noticed my injector pulse width is at 120% at WOT. What is considered maxed out on IPW? KR bumps to 3.5 at this point boost reads 9.9psi. ltft's are locked in at 0. 02 is at 925. Is it right to assume my injectors are maxing out thereby causing the bump in KR?
    Thanks
    06 GT, HPtuner, PLX Wideband, AFC2.0, K&N CAI, PEM/PLOG 3"DP, ZZP 3.5MPS, CORSA CATBACK, GMPP STB's, GMPP HD Tarms
  2. #2 Re: Injectors, what is the max duty cycle?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    You have your duty cycle % listed but what is the actual IPW?
    this may help RC Fuel Injection
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Injectors, what is the max duty cycle?
    I tried posting the IPW worksheet, but it's gone from my computer. Generally 20ms and under you are safe
    Injectors, what is the max duty cycle? Attached Files
  4. #4 Re: Injectors, what is the max duty cycle?
    Rochester, NY
    Quote Originally Posted by IndeedSS View Post
    Thanks for the reply. Sorry I only had % scan turned on so can't give actual msec time. I did do some looking around and it appears there is a difference in reported IPW vs actual IPW for non return fuel system. I guess pre-2004 has a return fuel system whereas 2004+ is a non return system and the resultant OBDII numbers reported by the PCM are about 32% higher than they are actually running (test results from charles @ DHP). So my actual % dcyc would be 88% which makes more sense. Looks like injectors are fine and I need to do some tuning. Good info with the links by the way. Thanks guys.
  5. #5 Re: Injectors, what is the max duty cycle?
    St Louis MO
    Darn returnless systems. You are correct there is a difference and what you said does make complete sense.
    2010 Camaro SS LS3
  1. injectors sizes
    By suprchrgd in forum Off Topic Discussion
    Last Post: 01-22-2008, 07:20 PM
  2. 42.5# injectors?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2008, 02:17 PM
