Thread: Shift Points
Results 1 to 9 of 9
  1. #1 Shift Points
    SE Level Member RicerKiller's Avatar
    Feb 2009
    Alabama
    My cousin has an HPTuner for 96-up GM OBD-II and he and I are going to start doing some tuning on my 2001 Grand Prix GTP tomorrow, he knows how to do pretty much everything as he has tuned his 02 Camaro Z28, but he doesn't know much about the automatic transmission stuff. so my question is what are the best possible "safe" shift points that I should use? I haven't done anything to the transmission or anything like that I have 40 series flowmasters, u-bend delete, res replaced with a 22" glasspack, cold air intake, Bosh platinum +4 plugs and thats about it. thanks for any and all advice.
  2. #2 Re: Shift Points
    TDCRacing
    Guest
    Stock transmission shift points.
    Change the desired shift time to .006 for performance or normal (wich ever you perfer) (assuming you have performance shift)
    And you can mess with the FT shift speed tables a little to get the car to perform a little better when it down shifts at WOT.
  3. #3 Re: Shift Points
    Barksdale AFB, LA
    Whatever shift points you decide on, program them in a few hundred RPM below. That's because there's a slight delay from hitting the shift point to the transmission finally completing the shift.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Shift Points
    Feb 2009
    Alabama
    ok. thanks for that info guys. We created my bin today, and did a scan everything went well I had a little KR like 5 @ WOT, but nothing serious we didnt have time to change many settings cuz i had to go to work. im going by jerry's tuning notebook, and he says to leave the torque management settings stock or to use the DHP V.1.5 settings. does anybody have these settings?
  5. #5 Re: Shift Points
    Barksdale AFB, LA
    If you don't have a DHP tuner, you're not going to get someone to give you settings out of the DHP file. Kinda like breaking the covenant, you know?
  6. #6 Re: Shift Points
    TDCRacing
    Guest
    Just change the TM settings to 256. That's about half way from where there at now. You'll be needing a new transmission soon if you've got much done to you're car.
  7. #7 Re: Shift Points
    Feb 2009
    Alabama
    my mods are as listed above. do you think it will mess up the tranny with just those if I change the setting you said to change. also if any of you guys have the HP Tuner software I can upload my scan and you can give me advice if you want to. thanks for all the info so far.
  8. #8 Re: Shift Points
    Quote Originally Posted by TDCRacing View Post
    nuh uh!
    stock GT tranny FTW!
  9. #9 Re: Shift Points
    Barksdale AFB, LA
    I haven't removed any TM from my car (except anything that shuts off injectors) and on shifts it pulls like a bat out of hell. All you need is a shift kit and your tranny will be safer (TM can still work properly) while you're faster (less time the PCM pulls timing since the tranny shifts faster).
  1. Rep points vanished ???
    Last Post: 11-03-2008, 05:43 PM
  2. What Trans Shift Points should I use?
    By Quicklynx in forum PCM Tuning
    Last Post: 10-25-2008, 08:04 PM
  3. Shift points
    By TDCRacing in forum General Tech Discussion
    Last Post: 05-28-2008, 02:26 PM
  4. Reputation points?
    By GreenNirvana101 in forum Off Topic Discussion
    Last Post: 04-15-2008, 05:29 PM
  5. WOT Shift Points...RPM/MPH
    By japslpr in forum PCM Tuning
    Last Post: 02-04-2008, 07:12 PM
