Thread: just another NOOB question about pcms...
Results 1 to 16 of 16
  1. #1 just another NOOB question about pcms...
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    so i bought an 01 gp gt.. I wanted to get a tuned pcm for it.. i narrowed it down to 2 choices (overkill,intense) i was about to order from intense but I don't know which to get or how to order the right one...
    if I go to the intense website it gives me a few choices i dont understand..
    Stock WOT ignition timing tables - ideal for supercharged vehicles where 91 or 92 octane fuel is the highest available
    Increase WOT ignition timing tables by up to 1 degree - ideal for naturally aspirated vehicles with any premium fuel, or supercharged vehicles with stock camshaft where 93 or 94 octane fuel is readily available (<b>+$20.00</b>)
    Increase WOT ignition timing tables by up to 2 degrees - ideal for naturally aspirated vehicles with any premium fuel, or supercharged vehicles with stock camshaft where 93 or 94 octane fuel is readily available (<b>+$20.00</b>)
    which one of those do i check off?
    also on intense.. it says
    Leave WOT shift points at stock settings - ideal for vehicles .with stock rocker arms and camshaft (<b>+$20.00</b>)
    Increase WOT shift points to approximately 6,000 RPM and engine rev limiters to 6,200 RPM - ideal for vehicles with higher ratio rocker arms and stock camshaft
    would it be okay to check off the second of the two? shifts points to 6k?
    so what should i go for.. the intense or overkill.. i really don't want to make the wrong choice.
    this will be the first mod on the car.. and i dont plan on doing too many mods because it's just a gt.. thanks for the help
  2. #2 Re: just another NOOB question about pcms...
    depending upon your mods it may not be a bad idea to pump up the WOT timing a little for a little more pep in the car. i would also increase the shifts to 6k for sure.
  3. #3 Re: just another NOOB question about pcms...
    Medford, NY
    that's what i figured.. but im not sure i really want to mod the car that much.. i just bought a cai from one of our members.. but that really doesn't do much.. and i'm probably not going to mod it more than just the pcm and cai.. only other things i might do are headers or a downpipe. that being said.. how many degree's of timing should i advance it?
  4. #4 Re: just another NOOB question about pcms...
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    I was wondering the same thing... Ha
    I will probably upgrade the rockers, at a later date (when I have the $$$)
    would it be ok to "Increase WOT shift points to approximately 6,000 RPM and engine rev limiters to 6,200 RPM - ideal for vehicles with higher ratio rocker arms and stock camshaft" but still run stock rockers for awhile? I plan on getting a PCM first, 3" dp, CAI, 180* t-stat, thinkin about the 3.4 pully (doing the support mods first) and colder plugs. Did I miss anything important?
  5. #5 Re: just another NOOB question about pcms...
    Medford, NY
    well i'm not doing rockers in this car and i think it would be fine for my rpms to do that.. im really just not sure about timing.. what should i pick?
  6. #6 Re: just another NOOB question about pcms...
  7. #7 Re: just another NOOB question about pcms...
    Medford, NY
    everyone agree's with dhp?
  8. #8 Re: just another NOOB question about pcms...
    GT Level Member cojo's Avatar
    Flint Michigan
    yea im curious too, I wanna get a PCM for my 03 gt. And am not sure where to get it.
  9. #9 Re: just another NOOB question about pcms...
    DHP is more of a general tune than anything. it will help, but hurt you more later on because it will be running so rich.
  10. #10 Re: just another NOOB question about pcms...
    Medford, NY
    yeah man.. i dont want that.. i want to be able to get a pcm that won't hurt my engine (if that's even possible) I'm not going to really be modding too much, i want to have the car for at least another 100k.
  11. #11 Re: just another NOOB question about pcms...
    Jersey
    I heard that 3800performance pcm was zzp's?
    16' wrx sti- stock
  12. #12 Re: just another NOOB question about pcms...
    Medford, NY
    yeah it looks like they use the same software
  13. #13 Re: just another NOOB question about pcms...
    Barksdale AFB, LA
    Running rich won't hurt your engine, it just might cost you a little top end HP.
    The best mail order PCM is the Overkill PCM. Other than that you need an in car tune or a dyno tune.
    2009 Subaru Impreza WRX STI
  14. #14 Re: just another NOOB question about pcms...
    Flint Michigan
    where can you get that done?
    and with the overkill pcm, you just send your core back to him right?
  15. #15 Re: just another NOOB question about pcms...
    Barksdale AFB, LA
    Quote Originally Posted by cojo View Post
    What, an in car or a dyno tune? For the in car tune, you need a tuner or you need to know someone with a tuner. For the dyno tune, any place that knows how to tune and has a dyno.
    Yep. Some people keep the cores as a backup, since occasionally PCMs do go belly up.
  16. #16 Re: just another NOOB question about pcms...
    Jersey
    I kept my core, and boy im happy i did. Hptuners here i come!
    16' wrx sti- stock
  1. Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    By Sinister Performance in forum PCM Tuning
    Last Post: 10-27-2017, 12:55 PM
  2. are zzp pcms anygood?
    By dmoney01 in forum Off Topic Discussion
    Last Post: 02-06-2009, 06:33 PM
  3. PCMs
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2008, 06:16 PM
  4. Noob with a GTP...
    By Just2Sweet in forum Introductions/Noob Questions
    Last Post: 08-25-2008, 01:44 PM
  5. a question about these PCMs...
    By agent505 in forum PCM Tuning
    Last Post: 06-02-2008, 07:24 PM
