so i bought an 01 gp gt.. I wanted to get a tuned pcm for it.. i narrowed it down to 2 choices (overkill,intense) i was about to order from intense but I don't know which to get or how to order the right one...
if I go to the intense website it gives me a few choices i dont understand..
Stock WOT ignition timing tables - ideal for supercharged vehicles where 91 or 92 octane fuel is the highest available
Increase WOT ignition timing tables by up to 1 degree - ideal for naturally aspirated vehicles with any premium fuel, or supercharged vehicles with stock camshaft where 93 or 94 octane fuel is readily available (<b>+$20.00</b>)
Increase WOT ignition timing tables by up to 2 degrees - ideal for naturally aspirated vehicles with any premium fuel, or supercharged vehicles with stock camshaft where 93 or 94 octane fuel is readily available (<b>+$20.00</b>)
which one of those do i check off?
also on intense.. it says
Leave WOT shift points at stock settings - ideal for vehicles .with stock rocker arms and camshaft (<b>+$20.00</b>)
Increase WOT shift points to approximately 6,000 RPM and engine rev limiters to 6,200 RPM - ideal for vehicles with higher ratio rocker arms and stock camshaft
would it be okay to check off the second of the two? shifts points to 6k?
so what should i go for.. the intense or overkill.. i really don't want to make the wrong choice.
this will be the first mod on the car.. and i dont plan on doing too many mods because it's just a gt.. thanks for the help
