Thread: High knock, add fuel?
Results 1 to 14 of 14
  1. #1 High knock, add fuel?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Hi all,
    I did a scan today and I am having issues with high knock. Going by my scan it looks like I need to add fuel, especially in the 9000hz and above. The wideband readings are at 19.6 which I believe is the highest it will read. Also it looks like the narrowband o2 reading are a bit low as well. My question is should I add fuel to these cells? Since they are so lean should I add at 4% or just do 2% at a time. Does this look like the correct thing to do to correct this knock issue?
    Scan. Dropbox - 2-6-21 SCAN.hpl - Simplify your life
    Tune. Dropbox - 1-28-21 new read.hpt - Simplify your life
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: High knock, add fuel?
    if the wb is reading 19's wot your way lean. add a load of fuel. it should ne 14'7 ish idle and cruise, then drop to mid 11's wot.
    make sure the o2 sensor is not dead too. they control fueling and can cause a lean issue and kr if bad.
  3. #3 Re: High knock, add fuel?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I added fuel and still got the same AFR readings. Less knock though. I think this stupid ZZP rear plog is leaking where the crossover pipe inserts. It crossover pipe barely fits to make a seal. I’m thinking that is the issue.
  4. #4 Re: High knock, add fuel?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Picture of how badly the ZZP Plog fits. Their customer support sucks. Just tighten it down they say, we usually don't have problems with these they said. I say make the damn part fit better. I should have left the crappy pacesetters on there.
    Dropbox - IMG_5215.JPG - Simplify your life
  5. #5 Re: High knock, add fuel?
    nice parts they sell. made in a america too ehh. looks like they hired some Chinese workers.
  6. #6 Re: High knock, add fuel?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yeah I have had issue with a few of their parts lately. The ZZP lateral arms had bad bushing inserts. The stock bolts wouldn’t fit through them. The rear plog mounting holes didn’t line up so I had to drill two of them out. Sucks spending that much money and having to modify the parts.
  7. #7 Re: High knock, add fuel?
    Oct 2014
    portland oregon
    I have old pacesetters. I wouldn't change them for any reason
    Sent from my SM-G981V using Tapatalk
  8. #8 Re: High knock, add fuel?
    Kemmerer, Wyoming
    headers are better than power logs every day of the week.
  9. #9 Re: High knock, add fuel?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Quote Originally Posted by rickisrad View Post
    well that looks like it might leak.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  10. #10 Re: High knock, add fuel?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    ZZP is trying to blame the crossover pipe insinuating I should buy one of theirs or a 97-05 year crossover pipe and it should fit. Well all those stock OE part numbers are the same. Blaming everything but their parts. Obviously by looking at the picture it doesn’t fit right and there is a problem.
    I replaced the Pacesetters because the collector was a pain to stay sealed and the flange was rusted out again. I replaced the collector a few times. Well I am a fool to have changed them out for these **** PLOGS. I should have replaced the collector and been good. What a dumbass I am!!
  11. #11 Re: High knock, add fuel?
    what a shi t show. maybe just put the stock rear on there and a 3 in dp?
  12. #12 Re: High knock, add fuel?
    May 2008
    Schuyler, NE
    Stock manifolds are headache free for hundreds of thousands of miles.
  13. #13 Re: High knock, add fuel?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I might see if the local shop BDK performance can weld a 2” extension on the crossover and be done with it. It probably wouldn’t be too expensive and end this headache.
  14. #14 Re: High knock, add fuel?
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    As far as I can tell, ZZP exists primarily to sell T-shirts and other garbage with their logo on it. I guess I'm happy they don't really support the LS4.
  1. High knock-runs like crap.
    By rickisrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2017, 07:14 PM
  2. High * of knock on stock setup.
    By OZZY1123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2014, 05:32 PM
  3. rich idle, lean when high rpm and knock?
    By copperpacecar in forum General Tech Discussion
    Last Post: 07-30-2010, 03:24 PM
