Thread: CASE Learn using DHP
Results 1 to 16 of 16
  1. #1 CASE Learn using DHP
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    I believe the Turbo needs a CASE learn after the work I did on the front cover. I have DHP. I can't find anything online about how to do it. I've also never plugged the tuner into the car, so maybe the button just shows up? Anyone done a CASE learn before? With DHP.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  2. #2 Re: CASE Learn using DHP
    GT Level Member mguzzo's Avatar
    Buffalo NY
    I'll look at the software tonight and post the procedure. Its kind of a hidden menu option then the prompts on the screen walk you through it.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: CASE Learn using DHP
    Dec 2015
    Chicago, IL
    Quote Originally Posted by mguzzo View Post
    Awesome. I would really appreciate that.
    243,000 miles
    CHICAGO, IL
  4. #4 Re: CASE Learn using DHP
    Buffalo NY
    Start the car
    Connect the DHP
    Select Scantool from main menu bar
    In the Scan Vehicle sub window select Real Time Control > Crankcase Position Variation Learn
    Follow the onscreen prompts
  5. #5 Re: CASE Learn using DHP
    Dec 2015
    Chicago, IL
    Awesome! About to give this a try. Thanks man.
  6. #6 Re: CASE Learn using DHP
    Dec 2015
    Chicago, IL
    Well, got DHP setup finally. With the correct drivers going through COM4. Got to the CASE learn screen. Started the learn. Depressed the parking brake after crossing my fingers, luckily it didn't get stuck!
    First it said can't do the test because of active DTC's. Cleared the active DTC code, the Crank Sensor code. Got the CASE learn going. But then got this message below. The car would only rev to 4000-4100 RPM before hitting the limiter. I thought it was suppose to be much higher then that?
    243,000 miles
    CHICAGO, IL
  7. #7 Re: CASE Learn using DHP
    thats the stock rev limiter in park or neutral. try again. i always let off at the first hint of limiter kicking in.
  8. #8 Re: CASE Learn using DHP
    Buffalo NY
    yep that's the RPM limit in park or neutral.
    got WOT until it stutters and let off. it just takes a plot second and you won't hurt anything. the PCM measures the variations on the way up and down.
  9. #9 Re: CASE Learn using DHP
    Dec 2015
    Chicago, IL
    Got it. I will have to try it again. It was 10:02pm and I don't think the neighbors were too happy so I had to quit. Gonna mess with it this weekend.
    It just seems like DHP gives you a small amount of time to get the test done. You gotta hurry. When it hit the limiter I just kept gunning it! BAHAHAH. Said GO WOT! So I did. I will let off this time at first hint of limiter.
    I really hope to get this done, cuz otherwise, I am leak free right now. Only problem is this damn code. Front cover gasket and seal are holding up. Despite the broken bolt and my Great Wall of RTV.
    243,000 miles
    CHICAGO, IL
  10. Likes ItHurtz liked this post
  11. #10 Re: CASE Learn using DHP
    Dec 2015
    Chicago, IL
    Can't get it to do the Learn procedure. Just keeps saying GO WOT! and then again GO WOT! I am going WOT damn it. It's like it's not sensing that I've got my fott on the gas. I don't know. I tried in Neutral as well. Revved to like 5,000+ RPMs with no limiter. I took my foot off the gas.
    The DHP book makes mention of this below, Case Learn Override. Anyone have any more insight as to what that is? And if it will help. Thanks
    243,000 miles
    CHICAGO, IL
  12. #11 Re: CASE Learn using DHP
    damn never had this happen. no clue on the override.
    you have any codes? maybe a cel wont let it go through?
  13. #12 Re: CASE Learn using DHP
    Dec 2015
    Chicago, IL
    I have that code for the cam sensor. I always have to clear it before running the Learn or the Learn won't initialize.
    243,000 miles
    CHICAGO, IL
  14. #13 Re: CASE Learn using DHP
    maybe its time to fix that issue. cam sensor and crank and icm all talk, if one is not talking back im sure thats why it failed to do the learn.
  15. #14 Re: CASE Learn using DHP
    Dec 2015
    Chicago, IL
    I thought the learn might clear the issue. Reading older threads it seems it will throw a code of it needs a Learn.
    I tried fixing the issue already. Replaced cam sensor with brand new Delco sensor. And replaced ICM harness with a “new” minty one. Left do is see if wire going to PCM is bad, or maybe I knocked the black magnet out somehow when putting the front cover back on? Didn’t want to take that cover off ever again. Fukk.
    Would anyone be able to provide a PCM pinout diagram that shows the Cam sensor input?
  16. #15 Re: CASE Learn using DHP
    Antioch, IL
    magnet is in the cam gear, doubt it would have been knocked out. Glad to see she still hates you LOL.
    2009 Challenger SRT8
    Expert at being gay.
  17. #16 Re: CASE Learn using DHP
    Dec 2015
    Chicago, IL
    Ohh. She hates me. She’s running. But not the best. She Burns SOOO much gas. Exhaust smells so rich. OMG. But no leaks from that front cover. Which was the goal.
    Also. Found the PCM info I need. Apparently I’m looking for the black wire, #7 pin, on the blue connector. That black wire is a common failure point on the Riviera. But the Riv’s wiring setup is a little different so the failure point won’t be in the same spot.
  1. Case learn and dhp help!
    By suitercrew in forum PCM Tuning
    Last Post: 05-25-2016, 04:52 PM
  2. Need help with CASE learn
    By fremmy182 in forum PCM Tuning
    Last Post: 06-13-2012, 08:42 PM
  3. Case Learn...
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-07-2012, 04:53 PM
  4. CASE Learn help
    By Agentlongwood in forum PCM Tuning
    Last Post: 03-22-2011, 09:33 AM
