Thread: Trim relearn question
Results 1 to 20 of 27
  1. #1 Trim relearn question
    Dec 2015
    Cadillac Michigan
    My cars was already fueling perfectly. I just changed some non fueling parameters. Do my trims still need to relearn? This was a partial write using dhp. when I last programmed it ltfts were right where I needed them from the start. I waited my hour drive time and four starts for wot run. I'm just thinking if I haven't changed any fuel parameters can I go wot from the beginning with no worries?
  2. #2 Re: Trim relearn question
    Why not just drive it and find out?
    If nothing changed fuel wise, nothing should change at all.
    HP Tuners resets with the flash because it's flashing the whole file every time and I've never had an issue.
  3. #3 Re: Trim relearn question
    Dec 2015
    Cadillac Michigan
    Good point lol. I have to wait a while until I can get back to my car. I was just seeing how others handled this sort of scenario. I figured a partial write it should be fine. I'm stock boost but pushing timing over stock quite a bit on this car. I may just wait 75 miles or so for good measure.
  4. #4 Re: Trim relearn question
    if you didnt change anything fuel related the trims will re learn and be the same as before. dhp seems to reset the fuel trims no matter full or partial flash.
    so just drive it.
  5. #5 Re: Trim relearn question
    Dec 2015
    Cadillac Michigan
    Ok awesome thanks.
  6. #6 Re: Trim relearn question
    how much more timing? have you tuned the pe folder and such? hate to see ya run to lean with extra timing added.
    id only add 2 degrees or less at a time. dont want it knocking to much all at once on ya.
    you have a wide band installed? those tell you your true afr. kinda needed if your tuning wot.
  7. #7 Re: Trim relearn question
    Dec 2015
    Cadillac Michigan
    No wideband for this car. It's been fueled and timed the same for over a month and a half now. Ever since it's been warm. It's a 97 buick riviera.
    I started programming my bottom swapped 2004 gtp and noticed shift times stock were below .3 which is what I had the riv set at. So the only thing I changed was my 1 to 2 shift times.
    I hit between 18 and 20 degrees depending on the day. Before i had it around 17 to 19 for like 2 months. Never any kr. The 1997 has a very flat mag curve so I manually raised it up as my Hz increased. I figured it's nothing too aggressive for a stock boosted car.
    My gtp on the other hand is l 36. I'm having a pcv issue at the moment. Once I get that straightened out a plx wideband will be going where the egr was. Shooting to lower timing 1 to 2 degrees from stock in that car.
  8. #8 Re: Trim relearn question
    Dec 2015
    Cadillac Michigan
    Oh I haven't touched pe afr on the buick and wont.
  9. #9 Re: Trim relearn question
    Dec 2015
    Cadillac Michigan
    Maybe 4 degrees isnt quite a bit of timing as i first stated but it's seem to run around 15 from the beginning.
  10. #10 Re: Trim relearn question
    Quote Originally Posted by Prd2010 View Post
    you really should touch it. pe stands for power enrichment, it sets your afr to a lower number making it richer as it needs to be really. then with the wb you can see if your matching whats commanded, if not you make a maf adjustment to make it match.
    and the wide band goes in your down pipe pre cat, not in the egr hole. that wont work at all.
  11. #11 Re: Trim relearn question
    They run overly rich from the factory, if all he did was add a little bit of timing that's not going to lean it out much if any.
    Factory is like 10.8-11.0 or richer if you are in the throttle long enough, it's just fine.
  12. #12 Re: Trim relearn question
    stock is 12.4 i lowered mine to 11.4
  13. #13 Re: Trim relearn question
    You are forgetting about the add vs rpm/time table that automatically reduces the commanded AFR.
    DHP may call it something different but HP Tuners is add vs rpm/time. All supercharged cars are set to 12.4 in the main Base AFR vs ECT table.
  14. #14 Re: Trim relearn question
    Dec 2015
    Cadillac Michigan
    I have no actual wideband experience yet. I swore I saw a post about using maybe it was the egr itself. Maybe that person has no idea what they are talking about like me lol.
    I did leave the ae table stock also. So with the 12.2 commanded plus ae enrichment that does sound rich to me also.
    The riviera only costs 500 dollars. I don't necessarily want to push it to where it just dies, but if it did my feeling wouldn't be too hurt.
    I'll definitely be getting a wideband for the gtp though. I'll plug off that egr hole now then, that's good to know.
  15. #15 Re: Trim relearn question
    Dec 2015
    Cadillac Michigan
    Acceleration enrichment on dhp. It's in time in or vs rpm
  16. #16 Re: Trim relearn question
    Dec 2015
    Cadillac Michigan
    ***it's in time in pe vs rpm
  17. #17 Re: Trim relearn question
    Dec 2015
    Cadillac Michigan
    Most people disable this I believe. But I have not
  18. #18 Re: Trim relearn question
    you can add to that folder too if need be.
    if you zero it out a maf adjustment will be needed up top. just learned that last month. as i ran out of fuel about the 1000 foot mark into a 1/4 mile pass.
  19. #19 Re: Trim relearn question
    We'll see if this picture works but it's from a random file I pulled on my computer a long time ago.<br>
    <br>
    It's just for reference.
  20. #20 Re: Trim relearn question
    May 2008
    Schuyler, NE
    Leave PE alone. They run rich enough stock. You don't have a wideband, so you are blindly adjusting it. Just keep it from getting kr, and you'll be fine.
  1. interior dash trim question
    By hockeybawler in forum General Grand Prix Discussion
    Last Post: 07-20-2014, 10:11 AM
  2. tb relearn
    By dsmuts in forum 04+ Specifics
    Last Post: 02-28-2014, 10:21 AM
  3. post-carpet install 2004GTP TRIM question...
    By gloebird in forum General Tech Discussion
    Last Post: 07-15-2012, 07:49 PM
  4. No Relearn for Overkill PCM?
    By 04CompG in forum PCM Tuning
    Last Post: 09-14-2008, 07:12 PM
