Anyone have a capable device? I bought a ZZP tuned PCM and it runs great but mileage is suffering. It doesn't as well before I had a relearn done after a crank sensor change. Anyone can help in Houston?
The case learn will not fix the gas mileage issue, that's due to the tune. I've swapped plenty of engines and crank sensors without doing case learns and they all ran fine. It's probably the tune.
Im fairly certain that if you need a case learn it would throw a code.... But I have done them before with DHP tuners. Also think MAYBE an areoforce can do it also.
Any improvement or not enough miles to tell?
No real improvement yet about 25mpg. The computer still says about 22.8 though. I filled with 93 octane and will see it that has any effect. It did seem peppier than before but could be wishful thinking.
Yes I can.
04+ GP’s won’t always throw a code when they need a CASE relearn. I learned that after changing the balancer and about 3 months later the thing started with slight misfires, that would kick off the cruise control, then progressed to the point where it would miss under heavy throttle then got to the point where it was missing all the time. The whole time I went through the plugs wires and coil packs. Finally just did a CASE relearn and it cleared ALL the misfires away.
Jeff
Man you are doing way better than me, must be a lot of highway driving. I couldn’t get better than 26.1 freeway and 17.1 for my normal back and forth to work on gas.
