Thread: Frankenstein Build???
Results 1 to 8 of 8
  1. #1 Frankenstein Build???
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Ok. Let me see if I can get this right...
    2002 Monte Carlo. 2004 Impala SS engine and trans. Should the 2002 PCM be able to run this combination? Buddy of mine is asking for my tuning assistance.
    Thanks!
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  2. #2 Re: Frankenstein Build???
    o4 monte got a gen 3? if not you need a tb adapter and a 2000 l67 tb for it. then you need to swap the trans tune and a load of other crap over
    if you can get a l67 2000 monte bin that would be the best thing to do.
  3. #3 Re: Frankenstein Build???
    just looked in my file of bins. no l67 monte. you'll have to set it up like a top swap's tune. trans, timing and map files are a must. and you need to get a 2000 l67 tb so you can still use your maf. the na tb is oval and dont fit right.
  4. #4 Re: Frankenstein Build???
    damn it, the tranny, iirc the 04 monte would of have the gen 3 blower and older style tranny, like a 03 gtp. you will likely need to do a pnp swap on it.
    heres bills how to on that. Wiring a external PNP switch to an internal PNP transmission - GM Forum - Buick, Cadillac, Chev, Olds, GMC & Pontiac chat
  5. #5 Re: Frankenstein Build???
    The Boss Iceman6669's Avatar
    Jun 2011
    If you need a certain bin file lmk. I’ll see if I can come up with one and upload it to the tune vault.
    2011 F-150 Yote powered
  6. #6 Re: Frankenstein Build???
    Wow.. Scott was all over the place.
    L67 was available in the Monte in both 2002 and 2004. No motor worries.
    Trans however... the valve body, pressure switch and channel plate are most likely the difference, besides the internal vs external pnp. I'd have someone like Scott or Iceman use a DHP to start with an 02 L67 Monte bin then drag the 04 Monte L67 trans onto it. Then stuff an external pnp you pickup super cheap from a junkyard on it and poof. All set.
  7. #7 Re: Frankenstein Build???
    What the heck.. I was sure 2002 was possible to have a supercharger. Hmmm
    Just drop the 04 bin in and smile maybe. Maybe drag the 04 engine and trans over in dhp to get it happy.
    Crap
    Chevrolet Monte Carlo Supercharged SS | Short Take Road Test | Reviews | Car and Driver
    Not til 04
  8. #8 Re: Frankenstein Build???
    May 2008
    Schuyler, NE
    04 files don't work on 2002's. You either need to have someone manually change your file to a 2 bar map or just run a 1 bar.
    I don't know of anyone that can change the files anymore, so you're probably just stuck with running a 1 bar.
  1. *UPDATED* GOOD BYE SE Hello Frankenstein! Build Thread *PICS*
    By willie14 in forum General Grand Prix Discussion
    Last Post: 12-26-2016, 07:07 PM
  2. Replies: 399
    Last Post: 08-17-2016, 01:35 PM
  3. trying to make an awesome Frankenstein GP. but need some info if any can help
    By awsardo2010 in forum General Grand Prix Discussion
    Last Post: 05-23-2016, 05:50 AM
  4. Welcome to frankenstein.
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 11-22-2014, 10:27 PM
  5. Projet Frankenstein (97 GT Sedan)
    By Mater in forum Members Rides
    Last Post: 02-14-2012, 05:02 PM
