Thread: Trans info wanted
Results 1 to 3 of 3
  1. #1 Trans info wanted
    Dec 2013
    laporte mn
    I'm wondering if anyone can tell me the trans info I need to put into hptuners for a 3.29 trans with a 245/40r18 tires.
    I have an 04 comp g
    Thanks
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  2. #2 Re: Trans info wanted
    There is only one table you have to change I believe, it's the VSS pulse per mile table. It's the only table that says it's with the gauge cluster.
    You'll have to hand calculate the number by hand using the gear size, tire size and VSS. You could play with the number lower or higher to see how close you come with a GPS.
    Or just run the correct size tires. 245/45/18's
  3. #3 Re: Trans info wanted
    Dec 2013
    laporte mn
    They don't make nitto nt05 tires in 245/45r18
  1. 04 GP replacing trans with used one info
    By dhdolphns in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-14-2016, 05:09 PM
  2. 02 Impala trans info needed
    By FordMan77 in forum Off Topic Discussion
    Last Post: 09-16-2014, 11:07 AM
  3. Trans Info?
    By speed demon in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-08-2014, 07:10 AM
  4. Trans info/links
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 07-19-2012, 09:33 AM
  5. Looking for Trans Rebuild Info
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2008, 12:03 AM
