Thread: New to DHP and tuning
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: New to DHP and tuning
    GTP Level Member
    Jan 2015
    Lincoln, NE
    DHP has a scanner built in...it is frustratingly inconsistent if there is another program that you can use to scan using the DHP hardware i would recommend that. Tinytuner is another editor that works with the DHP hardware. it is a very good tool and gives access to a lot of stuff that DHP doesnt, however, it is not mapped for every OSID and you may need someone to add your OSID to the database before you can view your .bin files with it. that is something i wish i would have learned how to do a long time ago.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  2. #22 Re: New to DHP and tuning
    Kemmerer, Wyoming
    tiny tuner is just a program that works with the dhp software. you can't read or write a bin with it. I used UV Scanner to take scans, and it was a lot more effective.
  3. #23 Re: New to DHP and tuning
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    Okay so I'm gonna need UV Scanner too for the best results lol would TinyTuner be useful to me if I'll I want to do is edit my maps to get rid of the bit of KR I have? I want meth injection but that won't be for a few months
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  4. #24 Re: New to DHP and tuning
    Kemmerer, Wyoming
    I wouldn't bother with tiny tuner, it's a little bit more advanced than what a new tuner is going to use. I am far from an experienced tuner, and never used TT when I had my dhp. as far as meth injection goes, the safe way to run it is to get your car tuned before you run it, and not adjust your air fuel ratio when it is spraying, that way if you have a pump failure or the meth doesn't spray for some reason, you don't lean out at the worst possible time.
  5. #25 Re: New to DHP and tuning
    Feb 2014
    Rhode Island
    Don't adjust the AFR when spraying? So just give it an optimal AFR for non-spray and just let the meth/water have its cooling effects? I gotta do some more research. I would love E85 but I don't have it in RI. And the IC is just to expensive for me right now
  6. #26 Re: New to DHP and tuning
    being you got a 01 in the sig there, tiny tuner is the only way to tune out the cat test and rear o2. you want to do that. or you can email me your bin once you read and save it and i can delete it for ya and email it back.
  7. #27 Re: New to DHP and tuning
    Feb 2014
    Rhode Island
    I have a rear o2 emulator, does that change things? I also just got the hardware in! SO FRIGGIN EXCITED LMAO
  8. #28 Re: New to DHP and tuning
    if you take the cat out or get a hi flow one the pcm over fuels. not sure that o2 emulator thing actually works on 01 up cars. you can delete the damn thing and sell the o2 emulator lol.
  9. #29 Re: New to DHP and tuning
    Feb 2014
    Rhode Island
    I have a cated 3" DP from ZZP too. I just made a backup of the ZZP PCM onto my computer. Want me to send it to you? Do you need to be plugged into the car when changing values? And should it be key on or motor running when plugged in? The emulator works with not ever throwing a cat code lmao
  10. #30 Re: New to DHP and tuning
    once the bin is on your pc you can just work on it at will.
    to read or flash to the pcm, car off, key to run only. i hit my e brake to kill the parking lights and then while its reading or writing dont touch a thing, turn the radio off fan off, leave the windows alone, dont even open the door till its done.
    ill pm you my email if you want the cat test killed off.
  1. Anyone have the tuning for a NIC CAM?
    By Shifty in forum PCM Tuning
    Last Post: 01-05-2013, 04:22 PM
  2. Tuning Help
    By 05GTPcmpg in forum PCM Tuning
    Last Post: 06-16-2011, 09:18 PM
  3. PCM tuning
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 03:16 PM
