Thread: More DHP woes
Results 1 to 9 of 9
  1. #1 More DHP woes
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    So when i finally got everything going again, the DHP scanner decided that it doesnt like recording all of the scan. I will save only a certain percentage of the scan. When i get the bar that tells me its saving, it stops before being complete and gets stuck there. Ive already reinstalled the program 3 times. any thoughts?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: More DHP woes
    GXP Level Member
    Mar 2015
    Tomball
    Mine has never completed a scan, I leave it sitting for about 30 minutes and it will only miss the last copule of rows so basically the time I'm sitting in the driveway.
    Jeff
  3. #3 Re: More DHP woes
    Apr 2014
    South Haven, MI
    Maybe ill just let it sit for a while then.
  4. #4 Re: More DHP woes
    you try uvscanner yet? saves instantly does a faster scan too and can run a wide band through it too.
  5. #5 Re: More DHP woes
    Apr 2014
    South Haven, MI
    UV Scanner? i havent messed with it yet.
  6. #6 Re: More DHP woes
    set it up, try it out.
  7. #7 Re: More DHP woes
    Apr 2014
    South Haven, MI
    Well the instant saving scan sounds ideal.
  8. #8 Re: More DHP woes
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Mine always hangs at 98/99%. I end up cancelling the scan and then closing it. The only time it will complete the saving portion is when it's a short scan of a few minutes. Anything over 3 minutes it will hang at the very end.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  9. #9 Re: More DHP woes
    Kemmerer, Wyoming
    uv scanner is far superior to the dhp software
  1. LIM Woes
    By EJOUIE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2015, 10:06 PM
  2. misfire woes
    By Silversurfer Gio in forum General Tech Discussion
    Last Post: 06-07-2014, 10:21 PM
  3. Trans woes
    By Ultra440 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-24-2013, 03:48 PM
  4. Alternator woes?
    By Bigjoe980 in forum Introductions/Noob Questions
    Last Post: 06-02-2013, 01:58 PM
  5. Subscription woes
    By Preotic in forum Off Topic Discussion
    Last Post: 02-01-2008, 07:28 AM
