Thread: Injector tuning ?
Results 1 to 12 of 12
  1. #1 Injector tuning ?
    Aug 2008
    SOUTH TEXAS
    I'm installing 42lb injectors tomorrow.
    And of course tuning it for the bigger injectors.
    But i also have a fuel pump rewire kit coming on thursday.
    Question.
    If i install the injectors and tune.
    Would i have to retune once i install the fuel pump rewire kit again?
    Would installing that fuel pump rewire kit throw my tune off?
    Since its supposed to increase the fuel flow.
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: Injector tuning ?
  3. #3 Re: Injector tuning ?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    you shouldnt have to retune for the fuel pump rewire.
    He might. When I did the resistor bypass, I had to do some serious tuning to fix the very negative fuel trims. I would think that the same would apply to the rewire to a lesser degree.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  4. #4 Re: Injector tuning ?
    its possible, but i cant see it doing much at all except on the top end where it is the only place youre losing fuel due to low voltages.
  5. #5 Re: Injector tuning ?
    Barksdale AFB, LA
    But the system will be sitting at a higher pressure any time the engine is running. More fuel will be injected for the same pulse width, and the fuel trim will have to go negative as the PCM compensates.
    It may or may not move your trims significantly. You'll just have to do it and see. At the worst one or two MAF tunes would do it.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Injector tuning ?
    TDCRacing
    Guest
    I can see where everyone is comming from. It seems like the only place that it would make a difference would be where you were not getting enough fuel at before. But I see these other guy's points also.
    Be sure to put that 42.5 IFR table in the pcm also. I have one if you need it.
  7. #7 Re: Injector tuning ?
    Aug 2008
    SOUTH TEXAS
    Ok thanx for the info guys.
  8. #8 Re: Injector tuning ?
    Aug 2008
    SOUTH TEXAS
    Quote Originally Posted by TDCRacing View Post
    I think the guys tuning me has one.
    If not, i'll pm you.
    Thanx!
  9. #9 Re: Injector tuning ?
    Barksdale AFB, LA
    I will soon. Care to copy me one?
  10. #10 Re: Injector tuning ?
    TDCRacing
    Guest
    Sure no problem. Sit tight.
  11. #11 Re: Injector tuning ?
  12. #12 Re: Injector tuning ?
    Aug 2008
    SOUTH TEXAS
    Good info, thanx for ur help!
  1. 99% Injector duty
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 11:13 PM
  2. injector removal
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 09:43 PM
  3. Injector cleaning, yes or no?
    By Sabrewings in forum General Tech Discussion
    Last Post: 10-20-2008, 12:17 AM
  4. No fire on #3 cyl, injector problems??
    By gplostinnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 12:28 AM
