Thread: Running out of fuel pump?
Results 1 to 2 of 2
  1. #1 Running out of fuel pump?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    what are some of the signs of out flowing a fuel pump?
    I did some more scanning today just to see how the car was doing. I made a few WOT runs and found out my o2 value dropped from 923 to 830-880 WOT. Im not sure if its because the o2 is hitting the firewall causing it to screw up or my fuel pump is now supplying enough fuel so its leaning out.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Running out of fuel pump?
    You can't trust narrow bands for anything really.
    You need to watch fuel pressure and injectors information. Like duty cycle, pulse width to see how the fueling of the car is working.
    Or watch your wideband, if you see it going lean. Then you either have a lack of fuel flow from the pump or the injectors arent big enough.
  1. 04/05 fuel pump install- Fuel pump access in trunk
    By chrsmi1 in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2015, 09:26 PM
  2. Replies: 7
    Last Post: 11-05-2014, 10:09 AM
  3. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  4. Trying to get the 90 Prix running... fuel pump questions
    By 90PrixSE in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-15-2012, 01:17 AM
  5. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
