Thread: Need help with lack of rear o2
Results 1 to 12 of 12
  1. #1 Need help with lack of rear o2
    Sep 2013
    Northwest Indiana
    alright, I've been reading around and deleting the rear o2 on these cars is common enough. Previous owner had it tuned perfectly, I thought I could do it better, couldn't, now I need some help. Seems like most people say to drive up to intense? I looked on their site and they said its $100 extra if your car leaks anything on their dyno? My car definitely will. I don't need a nice expensive dyno tune, I just want it to run right. Any suggestions?
  2. #2 Re: Need help with lack of rear o2
    Fix leaks then drive over there?
    04 Comp G.
  3. #3 Re: Need help with lack of rear o2
    Donating Users Uno99's Avatar
    Appleton, Wi
    Why are you wanting to delete the rear 02? Dont do it..... finding a way to get the cat test tuned out is not fun if you dont have DHP/Tiny Tuner and something Im working on as soon as my life gets back to normal.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  4. #4 Re: Need help with lack of rear o2
    All 97-00 cars do not have to worry about the cat test though, a simple shut the code off is all thats needed.
    So you have a tuner?
    What couldnt you do better???
    Tuning these cars isnt very hard.
  5. #5 Re: Need help with lack of rear o2
    Sep 2013
    Northwest Indiana
    I don't have a tuner sadly. The previous owner deleted rear o2 and the car was tuned for it when I bought it. It ran great and is already set up for not having one, plus the cat is going bad so I want to be able to run it without the check engine light on
  6. #6 Re: Need help with lack of rear o2
    Appleton, Wi
    Any idea what it was tuned with?
  7. #7 Re: Need help with lack of rear o2
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Quote Originally Posted by 00Daytona View Post
    If the check engine light isnt on now and the rear O2 has been deleted, the light wont come on if you eliminate the cat...
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  8. #8 Re: Need help with lack of rear o2
    Your post is a bit confusing to me, seems like others as well.
    Your title says you want help with a lack of a rear O2, then you mention it's already deleted and was running perfectly.
    You thought you could to better and couldn't, so you need help. With what do you want help? What did you do that didn't work better than how the car was previously running/setup?
    Obviously the car leaks (it's a 3800 so that's not a big surprise, but whatever) and you think you may want a dyno tune. If you undo whatever you did, wouldn't it run perfectly again?
    See where I'm going.. you aren't quite describing to us what was done or how the car isn't running right. Being an internet forum, we can only read and many times need a lot more info.
  9. #9 Re: Need help with lack of rear o2
    Sep 2013
    Northwest Indiana
    The car was tuned for not having a rear o2, I got an intense canned tune not thinking about it, and now the check engine light is on. I thought I was doing good by "updating" the tune but it only made things worse.
  10. #10 Re: Need help with lack of rear o2
    Ahhh thank you.
    Did you have the tune overwritten or do you have the old pcm/tune still?
  11. #11 Re: Need help with lack of rear o2
    Sep 2013
    Northwest Indiana
    Ahhh thank you.
    To be honest im not sure, I do know that the guy who tuned it kept the previous line pressure, and trans shift settings, and not being able to turn perf. shift on and off. So maybe the old tune is still in the computer in a way?
  12. #12 Re: Need help with lack of rear o2
    Sep 2013
    Northwest Indiana
    Forgive my lack of tuning know how. Im an under car guy. suspension is what I know best.
  1. Lack of power
    By Zach2013 in forum Engine
    Last Post: 11-30-2014, 11:38 PM
  2. Lack of power when passing
    By jasonnovak in forum General Tech Discussion
    Last Post: 09-25-2014, 11:22 PM
  3. lack of starting
    By xtreampony in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2013, 08:39 PM
  4. Lack Of Power
    By Crocitto49 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2013, 06:56 PM
  5. 2002 gtp lack of power
    By gtp2002 in forum Introductions/Noob Questions
    Last Post: 02-22-2010, 01:29 PM
