Thread: Trying to decide Overkill or ZZP tuning
Results 1 to 20 of 33
  1. #1 Trying to decide Overkill or ZZP tuning
    SE Level Member Robby Avery's Avatar
    Deep South Georgia
    I'm trying to decide on tuning here which will be better for a 2003 N/A grand prix. future mods are power log, 3in dp, tb spacer, and tuning. just need input on which is going to be the best tuning for the buck. Thanks in advance
    Girlfriend's ride: 03 Summit White Grand Prix GT 180* T-stat, Autolites, Bosch wires, Custom CAI
    My Rides: 2006 LBZ CCSB LT3 Duramax Diesel Puller/DD
    2002 LB7 Duramax Diesel CCSB LT3 to many mods to list! Work Truck/DD
  2. #2 Re: Trying to decide Overkill or ZZP tuning
    TB spacer...lol, skip that.
    Buy a PCM from 3800Performance.
    It's a DHP...done and done.
  3. #3 Re: Trying to decide Overkill or ZZP tuning
    Nov 2012
    Madison
    Wouldn't you want headers and a HV3 for a N/A
  4. #4 Re: Trying to decide Overkill or ZZP tuning
    Deep South Georgia
    500 is my set spending limit so thats my simple recipe
  5. #5 Re: Trying to decide Overkill or ZZP tuning
    I live here. DirtDog's Avatar
    Jun 2012
    Definitely headers not dp and all that
    TB spacers are waste of money
  6. #6 Re: Trying to decide Overkill or ZZP tuning
    Quote Originally Posted by marines542 View Post
    His n/a so unless he wants to lose some low end torque a plog and downpipe is good enough for him.
    04 Comp G.
  7. #7 Re: Trying to decide Overkill or ZZP tuning
    Deep South Georgia
    How are spacers a waste of money? cool sound and a tiny bit more air every little bit helps IMHO. Still up in the air on tuning here?
  8. #8 Re: Trying to decide Overkill or ZZP tuning
    I like my overkill tune
    04 Comp G.
  9. #9 Re: Trying to decide Overkill or ZZP tuning
    Deep South Georgia
    Have you ever tried any other tuning? If so how would rate them on a scale of 1-10
  10. #10 Re: Trying to decide Overkill or ZZP tuning
    I purchased a Zzp PCM way back when I first got the car I was not a fan seemed to cause more knock then the stock PCM. Down the road added more mods and went the overkill route could not be any happier..it killed a lot of knock I was getting. The trans shift points were firmer. I rate it a 10 I will in the upcoming months will be making a drive to have a local adjust it for cam and getting my a/f were it needs to be instead of sending it back for a retune.
    A few guys seem to have problems with Zzp tunes lately. Only downfall to overkill is it takes time to get in contact with him and since he's in Canada shipping takes time.
    04 Comp G.
  11. #11 Re: Trying to decide Overkill or ZZP tuning
    Deep South Georgia
    Ok one last Q is the 185* fan on offered by overkill like the competitors noticed it doesn't say any where on the site.
  12. #12 Re: Trying to decide Overkill or ZZP tuning
    Sure is
    04 Comp G.
  13. #13 Re: Trying to decide Overkill or ZZP tuning
    Apr 2012
    nova
    Has anyone gotten a tune from intense racing?
    1999 gtp coupe... P&P heads, lim, and sc, comp vs cam, intake, dp and ubend
    2003 ford ranger fx4 level II- twin stick
  14. #14 Re: Trying to decide Overkill or ZZP tuning
    Intense was known to blow up your tranny.
    04 Comp G.
  15. #15 Re: Trying to decide Overkill or ZZP tuning
    A tb spacer is a waste because it doesn't make you flow more air and is a possibility for a coolant and vacuum leak.
  16. #16 Re: Trying to decide Overkill or ZZP tuning
    Deep South Georgia
    Ok good deal see if I can swing the good winter deal he has going
  17. #17 Re: Trying to decide Overkill or ZZP tuning
    Hey guy, why did you make 2 threads about the same topic?
    http://www.grandprixforums.net/need-...ods-74241.html
  18. #18 Re: Trying to decide Overkill or ZZP tuning
    Banned
    Jan 2013
    Colorado
    Is there a difference in price between the two?
  19. #19 Re: Trying to decide Overkill or ZZP tuning
    antioch ill
    depends on what you want done
  20. #20 Re: Trying to decide Overkill or ZZP tuning
    The PCM won't be worth the investment. I had one. Returned it shortly thereafter.
    Only thing I noticed were different shift points.
    TB spacer will be equally pointless.
  1. can't decide...
    By canuckgxp in forum Tires & Wheels
    Last Post: 03-26-2012, 07:03 AM
  2. help me decide
    By the other guy in forum Off Topic Discussion
    Last Post: 07-29-2011, 04:38 AM
  3. What to decide on....
    By Iron Indian in forum Tires & Wheels
    Last Post: 02-19-2009, 02:09 AM
  4. Trying to decide on a cam for my build
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2008, 06:19 PM
