Found this plug tucked behind the windshield washer reservoir. Anyone know where it goes?
Yes the washer works. I was thinking maybe it goes somewhere below the engine. Idk.... I don't want to say forget it as the car is not running to its full potential. Guess I'll have to tear into the engine.
What he said. Check for codes... if there is a **** Circuit low or ***** Circuit high or something like that .. .you found your problem
Nope no codes only p0442 which I have to change my rusty fuel and evap lines
2000 Buick PA Ultra
Not necesarily all unplugged things will set a CEL, I deleted my airpump in my 00 Bonneville, just unplugged it, no codes every showed up. Come to think of it... that plug looks similar.
Its lacking power and slightly rough idle. I remember changing the plugs and didn't feel any restored power at all. Plus my mpgs are low I'm getting 15 mpg city and highway. I checked fuel pressure its 42 key on. When I prime it, it shows 48 then goes down a couple psi. When I start it and remove the hose to the for it jumps to 50 psi
I've just disconnected my air pump from the rear since it never worked and installing the ak29 adapter so I can manually put air into my struts.
