Thread: Its been a while I need your guys help
Results 1 to 10 of 10
  1. #1 Its been a while I need your guys help
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    SO since the Pontiac got totaled ive switched to the LX platform and I have been loving it!
    But the help is scarce, I this issues is universal so maybe one of you guys can help you never let me down in the past!! Im in the middle of lowering my 2012 Dodge Charger R/T with Eibach springs
    So I took everything down and im re installing the new ebiach springs and im working on the rear and I cant get one of the rear carriage bolts to re install? Specifically the Rear Passenger Side.
    I lowered the carriage to clear the springs and struts and everything was goin fine in the re install but this one bot is now spinning loose. Its stuck just spinning wont go up or down whats goin on?
    It felt like it was lined up at first and I was able to thread it a ways, this is the supr long carriage bolt and not its just stuck spinning. Any help fellas?
    Pictures attached
    As always thanks guys!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Its been a while I need your guys help
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Can you put upward or downward pressure on it to maybe catch something to thread in or out?
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Its been a while I need your guys help
    Marysville WA
    I tried that it seems to go to no where up and when I pull down the threading is really skippy im kinda torn and thinking about tearing apart the trunk and liner to see if their might be access to the top of the frame??
  4. #4 Re: Its been a while I need your guys help
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Your sure it's lined up and started in the actual nut? Sounds like when you do a subframe and tighten all the bolts down and then last one wont go in cause it's just a hair off, loosen the other bolts and it will line up and start then tighten all and your good. But if it won't back out at all even with a bit of pry force maybe the nut welded to frame broke loose and your up the creek without a paddle.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  5. #5 Re: Its been a while I need your guys help
    Marysville WA
    Heh well the consensus is back out the other three and see what that does. Lord knows I hope some random nut didnt break loose in my frame. Not likely I didt give it much force when I was putting it in. It just made that (I know this will sound ironic) cracking sound bolts make sometimes when your driving in/out a dry bolt.
  6. #6 Re: Its been a while I need your guys help
    Marysville WA
    So I backed everything out and its still wont thread properly it feels like the nut inside the frame is loose? Is their access it that nut topside like through the trunk?
  7. #7 Re: Its been a while I need your guys help
    Feb 2010
    Oklahoma City, OK
    I stay as far away from Chrysler products as I can lol, so I couldn't tell ya. Best advice I can give would be to go to the dealer and have them print some diagrams or at least show you on their computer the area your looking at before tearing half the car apart to find out you can't get to it. Or if you have or know someone with alldata on that car they can see pretty much all diagrams the dealer can.
  8. #8 Re: Its been a while I need your guys help
    Marysville WA
    HehI just cant get the rear differential carriage to line up so I can thread the bolts every time I try a different corner runs into the same issue. Bleghhhh
  9. #9 Re: Its been a while I need your guys help
    Just leave it alone and trade it in for another GP and be done with it.
    04 Comp G.
  10. #10 Re: Its been a while I need your guys help
    Marysville WA
    Heh if only!
  1. Any gun guys out here?
    By Sudden in forum Southeast
    Last Post: 02-13-2012, 07:46 PM
  2. hey guys could use some help
    By grandprixman in forum Turbo
    Last Post: 08-22-2009, 01:32 PM
  3. Hey guys
    By mosley1990 in forum Introductions/Noob Questions
    Last Post: 08-09-2009, 11:38 PM
  4. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
