With me using the OEM cooling system needed to make a place to put the electric fans.This will house one of the Ultra's fan's and 2 7" fans.
Finish the fan's. I just love riv-nuts!
Nice work cant wait to see this done! I love swapped vehicles! Who gives crap about what someone bought from a dealer, home built swapped vehicles are way way cooler!!
Got some time to build some brackets and now looking at what will fit? Still need to install blower but need to change blower shaft seal. Found that after after installing the new oil?
Just a heads up for people pulling a old blower puller. Pull the snot and use a press. I used a puller and bent the pullley. And damaged the puller. On the the press it was at 10 Ton's ,and then a very load pop. Then it pressed like I thought it would. Some wear on the seal area, but I think it will clean up. Bearing are smooth and could be reused.
Now I will need a new pulley. Maybe one that can be changed ? Maybe I will go to the ceramic bearings?
your supposed to use a special puller for the sc pulley. hell i bet you could make one with your fab skills. check zzp's web site, they rent and sell the puller. and have a pic of it. wink wink lol
I used my pulley puller yesterday and it worked great
May have been just my turn?
I have been pulling blower pulleys on our SC motors (Mercury Marine) for years with it.
Maybe it just had one to many? I think it just had a little bit of rust ? And that will stop it DEAD!
Oh well ! Now I get to play with pully size!
What does your puller look like?
I'm not at the shop,but it looks alot like the Intence kit.
I've never had a stock GTP pulley come off without bending. I've used ZZP, Intense, 3800 Performance, and Thrasher pullers.
Nice project though! Looks like you're doing it right.
-Rob
Love the fab work.
Can't wait to see it done.
My buddy had an old Bravada in high school we were gonna drop a SBC in, but I like this much better.
Need some help.
Got the new (Intense ) pully kit.
How far down do I install the pully mount?
Got a email out to Intence Racing but think their closed?
Thanks,Randy
Flush it is. Thanks.
Also just looked a the new pully and it is a 8 rib. Wish I could use it but I'm cheep.
Why not the turbo, I guess I just like the look of the blower? I will leave the turbo for my 1994 JDM Sti.RHD.
