Thread: l67 camaro
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 110
  1. #1 l67 camaro
    Aug 2013
    tallahassee
    Hey guys, just joined this forum, but I've been floating around others for years. I'm posting up my l67 camaro build. So far in early stages and its gonna take a long time, but so far the plans are this, I've got a stock l26 bottom end with 68 k on it, and putting top end from l67 on it, porting and polishing the blower, intake, and heads. Will have 105 springs, xp cam, (maybe hardened pushrods?), single roller, meth injection, 42 injectors, 255 lph fuel pump, tune of course, and smaller pulley (not sure of what size to go yet). The goals are 350-400 whp so I guess I'm setting my hopes pretty high. Right now my mods are full exhaust w/headers, vogtland springs, stagg shocks, tubular trailing arms, tubular adjustable panhard bar, 32mm front and 23mm rear sway bars, poly bushings on all susp. Parts. Right now I'm in the process of rebuilding the m90, but here's the donor motor and blower. Still need quite a few parts but I'm still collecting so I'll get there soon enough. I don't have any pics of the car right now because it looks like crap Haha. In the process of a 2 stage full urethane paint job on it as well. And she has the ss 10 spoke rims.. I'll update y'all as the project continues (slowly). Any input or advice is welcome as this is my first paint job and motor build. (Lol been working on cars 9 years and never fully built a motor or did complete paint job). Hopefully the years of research on body work and 3800 builds will pay off.
  2. #2 Re: l67 camaro
    Did you remove the coating on the inside of the blower? That might not have been the best idea, from what I remember reading removing the coating makes the blower less efficient.
  3. #3 Re: l67 camaro
    Aug 2013
    tallahassee
    Well unfortunately the coating was coming off when I received it, and since I'm spraying meth/water, I went ahead and removed the rest, don't want that stuff going into the combustion chambers, I'll run a smaller pulley to compensate for the 1-3 lbs loss of boost. Lol now I'm wishing I just got a gen 5, but the fitment issues on the gen five are way worst the the 3 on fbodys
  4. #4 Re: l67 camaro
    Cambridge, Ontario Canada
    Won't stripping the rotor coating cause a lot more heat?
    2005 E55 - stock
  5. #5 Re: l67 camaro
    Aug 2013
    tallahassee
    It maybe a bit hotter, but the meth will be sprayed into the blower by the throttle body to cut down high temps
  6. #6 Re: l67 camaro
    should be a sick ride when done. your doing a top sway technically, not a L67.
    you should just find a used blower, they cost about a 100 used for a gen 3 less at at a junk yard.
    and you need to fab up a TB intake tube to the blower inlet because the TB wont fit due to the firewall being to close. its been done before, not sure if the tb tube is being made and sold or not, every one ive seen looks different and home made.
  7. #7 Re: l67 camaro
    found a crap vid, but it shows the tb relocation tube. they are made of metal every time and bolt to the blower inlet.
    vx supercharged calais l67 - YouTube
  8. #8 Re: l67 camaro
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Cool project! With enough meth/water mix being sprayed it should not only cool the temps but also "fill the gaps" so to speak and tighten the tolerances in the blower while cooling making up for the lost coating so you may not need to downsize the pulley to make up for the lost coating. Keep us posted.
  9. #9 Re: l67 camaro
    Don't even worry about not having the coating, I don't see why people think its such a big deal on these Gen 3 blowers, they arent gods gift to man.
    Run what you got, see how much boost it makes and just drop a size if needed.
    Because 40 bucks for a pulley is way cheaper than 100+ for a supercharger plus gaskets and your time. Think smarter not harder.
  10. #10 Re: l67 camaro
    Aug 2013
    tallahassee
    Thanks y'all for the input. And yes I know all to well about the fiasco with the throttle body. I have to cut a 3" box into the firewall to make an elbow fit because I won't be modifying the housing. I'm going to run it without the coating first and see how it goes. Worst that can happen is the boost drops a tiny bit. What size pully do y'all think I should go with for the hp goals? Remember its an l26 bottom end so compression a little higher(9.4)
    Oh and scottydogs. I believe that a vid of a holden rwd. Only in the down under. They came stock like that with an m90
  11. #11 Re: l67 camaro
    St. Louis
    On the pulley size, I'd start with the stock pulley and then get yourself a way to scan for KR (Aeroforce or the like). If no KR then drop pulleys. I hope you have headers on that list of things to add. Don't want to chip any pistions right off the bat.
    Are you going to be tuning this as well?
  12. #12 Re: l67 camaro
    Aug 2013
    tallahassee
    Already have headers, going to heat wrap them and the radiator hoses to cut down on heat and kr hopefully. I have an app on my tablet to wirelessly connect to my PCM to check for knock and any other readable engine stats/sensors, its called torque on the Google play store, its a life saver, and cheap!
  13. #13 Re: l67 camaro
    Don't wrap them
    04 Comp G.
  14. #14 Re: l67 camaro
    Aug 2013
    tallahassee
    Any particular reason its a bad idea?
  15. #15 Re: l67 camaro
    Jan 2009
    Tallahassee, FL
    Hi Kyle
    The wrap holds water and can rust the headers faster. Then again my exhaust is wrapped but I plan on getting headers one day.
    I forgot but are you doing any valve train or head work?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  16. #16 Re: l67 camaro
    Aug 2013
    tallahassee
    Hey justin. Definitely, putting on 105 springs, singleroller set. And maybe hardened pushrods if its really necessary. Also an xp can and heads/intake/blower will be ported and polished. Also, they sell a special silicone spray on sealer for header wrap that prevents water getting trapped inside
  17. #17 Re: l67 camaro
    Oct 2012
    Nowhere NY
    How are those stagg shocks treating you? ive heard mixed reviews and know no one personally that have em
    Ive been medicating with burnouts and alcohol
  18. #18 Re: l67 camaro
    Aug 2013
    tallahassee
    I love them. Awesome price. Ive put 1k miles on em. Much stiffer and sportier feel. I can take corners at a much higher speed. Well worth the money. Don't let bilstein or koni fanboys tell you theyre garbage, especially since they probly havent even drove a car with them. That being said I'm sure konis would be better. But these awesome for the money.
  19. #19 Re: l67 camaro
    Jan 2009
    Tallahassee, FL
    Koni fanboy right here
    77 Morris Garage B
  20. #20 Re: l67 camaro
    Aug 2013
    tallahassee
    Lol we all can't spend the big money on konis Justin. This thread is all about build on a budget Haha. Wish I had konis though I hear they're amazing
  1. 97 l32 camaro
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2012, 06:34 PM
  2. So Im trying to buy this Camaro...
    By SuperSport in forum Off Topic Discussion
    Last Post: 01-21-2011, 07:09 PM
  3. LT1 Camaro
    By ls1camino in forum Track Sessions and Kills
    Last Post: 11-21-2009, 02:14 AM
  4. Camaro vs Evo
    By SlowM90 in forum Track Sessions and Kills
    Last Post: 08-30-2009, 03:26 AM
  5. Camaro
    By bloxmagic in forum Track Sessions and Kills
    Last Post: 07-03-2009, 02:09 PM
