My GirlFriend has a 2001 Olds Alero and her Trac off light abs light and service soon light is on and it makes road noise, Im almost positive its the wheel bearing but i was wanting to see if you guys know if that might be the prob.?
I would scan it and see what wheel is throwing the ABS code and what that SES light is.
Also if its making road noise, is it louder turning one way or another?
How can the lights all be on, but no codes?
Can your code reader read ABS codes?
Road noise can be from the tires aswell. They could be crap tires or they are low on tread or have cupping.
You can also jack the car up in the air with the key on engine off and shake down the front end to make sure nothing is loose.
Yeah im rotateing the tires for her tomorrow so ill check everything, and idk if my code reader can read ABS, but when i tryed shuting the Trac off and on it just stayed as Trac off.
If all her lights are on it has codes. Make sure her fuse isn't blown to the obd2 port.
