Thread: 2001 Chevy Venture No Crank
Results 1 to 5 of 5
  1. #1 2001 Chevy Venture No Crank
    Donating Users GT2000's Avatar
    Oct 2017
    Central PA
    I have a 2001 Chevy venture that won't crank or even try to. All the gauges come on and work, along with the hvac controls and radio and all that stuff, but turn the key and nothing. Battery is fine, all fuses are good, however... several fuses are not RECEIVING power. They are not actually blown. Have to check what each one is, i know one of them is for the fuel injectors. This all happened when i was wiring up a fan toggle switch and i think something touched while working in the fuse box, cause that is when this started. I when on a whim and replaced the ignition module with a used one, and that didn't change anything. I'm starting to think the PCM got fried, and i assume a used one would have to be reprogrammed. Are the PCM's in the intake air box on these? Any input or other ideas would be appreciated.
  2. #2 Re: 2001 Chevy Venture No Crank
    Do all the dash light go off when you turn it to start?
    Does the starter turn if you jump the terminals with a screw driver?
  3. #3 Re: 2001 Chevy Venture No Crank
    Oct 2017
    Central PA
    The check engine light at least doesn't come on when key is on. Abs and brake and seat belt and airbag do, and turn off when u hold it in start position, but no check engine
  4. #4 Re: 2001 Chevy Venture No Crank
    hear a click form the dash when you turn to crank when the dash blacks out, like it should, most never notice. if you hear a click the starter is bad.
    you can also check the key is actually telling the starter to work by putting a test light on the small stud, then have some one turn the key to crank, it should light up. and if it does light up the starter is bad for sure.
  5. #5 Re: 2001 Chevy Venture No Crank
    Oct 2017
    Central PA
    Okay, ill have to try and see if juice is getting to starter, but i don't remember hearing a click.
  1. 1998 Chevy Venture - $250 Rat van to Brat van Ad-Venture!
    By BrandonHall10 in forum Members Rides
    Last Post: 02-16-2018, 09:56 PM
  2. 4T65E on a 2000 chevy venture
    By izup69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2014, 05:14 PM
  3. 02 Chevy Venture
    By Below Average Joe in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-18-2012, 12:59 PM
  4. Oil leak on my Chevy Venture with 3.4
    By Below Average Joe in forum General Tech Discussion
    Last Post: 02-08-2012, 08:38 AM
  5. Did they ever make a boosted chevy venture stock ?
    Last Post: 04-19-2009, 01:29 PM
